How do I clean the hot-end?
Cale
Post by Cale »
Today I printed a gear for a cube gear I'm printing.I left the print for awhile thinking it was good.When I got back I saw the hot-end was stuck to the print ,mid-print, and couldn't move.After I stopped it I got the hot-end off the the print and decided to clean the hot-end.My dad and I tried to get it off but,it was stuck VERY well.How should I clean the hot-end without breaking it ,and keep it on loose enough so I can easily maintain it? :?:
teoman
Re: How do I clean the hot-end?
Post by teoman »
You could heat it back up, it should let go of blob that it is holding on to.
Removing the nozzle and putting it in an oven is done by some to get the pla or abs to ooze out.
Putting the nozzle in acetone would dissolve the ABS.
IF the nozzle is badly clogged you can insert a micro drill bit inside to clean it.
That is all i can think of at the moment.
Cale
Post by Cale »
Sorry it's been a few days , I've been busy.I just want to say thanks to Teoman for helping me solve this problem.I haven't used it yet,but I now know what to do for cleaning the hot-end.
Cale
626Pilot
Post by 626Pilot »
If my nozzle has junk in it, I heat the printer up to temperature, remove it, then blowtorch it. It works pretty well. Whatever's in there is reduced to vapor in one or two minutes.
Also tried torching a heater block from an E3D hot end. That's not as good as an idea. Nozzles are brass and can withstand a thousand degrees for a couple minutes without deforming, but aluminum heater blocks can be ruined easily by doing so.
I had a failed print once (bad gcode) where the effector stopped moving, but the extruder kept feeding. An ABS blob had completely encapsulated the brass nozzle. I let it cool, and when I pulled the nozzle out of the hardened blob of ABS, it took all of the gunk with it and it looked shiny and new.
I'd advise against drilling the nozzle orifice, unless you're a machinist and actually have tiny gauged bits to use and can put it in a fixture and drill it true and plumb... I don't have those tools at my disposal, so I've used welding tip cleaning wire and guitar strings in an effort to push out a clog rather than cutting it out.
626Pilot
Post by 626Pilot »
I had a clog a few weeks ago that couldn't be burned out, so I took one strand out of a stranded wire. I was able to knock the crud out with ease.
PrintableStudios
Post by PrintableStudios »
With previous hotends, I picked up some blood sugar testing needles to clear the clogs in a .2 and .4 mm nozzle. I'm going to need to pickup a larger gauge for the .5 mm nozzle on my shiny new V2, but I have found them quite effective.
