nitewatchman wrote:Hunin wrote:One thing I wish is the nylon screws for the front panels had philips screwdriver head in addition to the knurled head. My hands are killing me from taking on and off the panels with these screws.
Shortening the screws helps a bunch!
That's a really good idea! I may give that a try.
I spent a few days investigating my issue with the hot end. I tested all of the wiring to the hot end and the wiring was getting continuity through out. I tried moving the wiring around inside and the continuity didn't break.
I took the hot end completely apart and tested the looked at the soldering for the thermistor which looked good. I tested the thermistor at the solder joint and it gave me a resistance in the K ohms. I tested the wiring up to the quick disconnect connector and it also gave me a resistance in the K ohms. So I put the hot end back together and took another look at the quick disconnect connector.
I already redid the female crimps and I can see the metal pins coming to the end of the housing. I have tried to shove the male pins further in to the housing because I think this was where the problem lay. It didn't work so I took a dremel and removed some of the plastic from the pin end of the housing. I put the connectors back together and it worked! The male pins really are not making connection to the female pins in the connector.
So I put everything back together and ran through the manual movement test procedures in the manual. While the hot end was moving, the nozzle gave me def error again. Forced the male pins back in the connector, rebooted and got an actual temperature. Moved the hot end and got an error again. So the connector is very sensitive and won't work for any "real" printing.
So now I'm looking to scrap the 1x4 0.100" latching connectors and redo the connection again. I have some extra JST connectors which I will try first. I've also thought of using a standard 4 pin molex connector similar to the old power supply hard drive connectors.
