So my day.
printed the peek shroud- didnt turn out great. somehow it was 4mm taller (im guessing scaled up somehow all around) than it should have been... so scrap that.
Went on to print the layer fan. Not sure if its the right size yet or not, but ill check... quality is still suspect.
Tried to print another peek shroud but the hot end thermister broke loose and smoked before i knew it. The grey plastic part (dont know what its called off the top of my head) started to deform and the nozzle was askew about 25 degrees.
I let it cool.
Back at it.... with the head upside down in a vice.. I heated the head back up, SLOWLY, just to the point of malleable plastic grey piece. I held it in place, as close to level as I can (its quite good) until the head cooled enough to hold it on its own.
I then let it finish cooling. removed by hand as much of the High temp RTV around and in the head as i can, refilled the cavities, and re-set the thermister inside the hole. I made sure i was VERY liberal with the RTV this time.
So now its curing... I wait...
SO my question to the board is..... What are the chances this has any chance of working again? And even if it works, any chance of it working well?
Reason i ask is, im considering buying another hot end, and asking the folks at seemecnc to overnight it tomorrow so i can have it friday.... If i wait for this to cure, i wont get that chance tomorrow.
Sorry for the long post, but im so excited to get to printing, and yet, set back after setback stops me.
