Rostock Max - Stalled at Home Position in Repetier
Hello All,
I am a little concerned here. I have made it through the entire build, no problems.... But I got to page 224 in the manual and after my Rostock Build passed the X,Y,Z limiter test within Repetier the problems began. When I hit the home button instead of the cheapskates going up or down. nothing happens. My LCD screen on the last line now says Home Delta. But the carriages never moved. I double checked the wiring, and settings... and then checked again. What could be going on here?
- redoverred
Re: Rostock Max - Stalled at Home Position in Repetier
I get that quite often, especially after using the extruder buttons in Repetier Host. Just disconnect, turn the printer off and back on again, then reconnect and it will work itself out.Noob wrote:Hello All,
Thank you for htis, but I tried this too. The motors are simply not responding in anyway to the commands issued by Repetier. In the log field I can see the commands rattling off, and I can see the LED processor light on Rostock thinking about what it has just been told, but absolutely nothing happens. No movement on any axis, no noise, nothing...
I am using Repetier .92, Windows 8, and have followed instructions to a tee.
Any suggestions? Thank you so much.
Are the motors stiff or lose? I.e can you move the carriages up or down?
Here is a copy of the log command field upon connection:
07:41:51.355 : OpenGL version:4.2.0 - Build 10.18.10.3316
07:41:51.357 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_INTEL_fragment_shader_ordering GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shader_image_load_store GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_compute_shader GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_shader_storage_buffer_object GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode
07:41:51.357 : OpenGL renderer:Intel(R) HD Graphics 4400
07:41:51.357 : Using fast VBOs for rendering is possible
07:42:17.684 : start
07:42:18.932 : Free RAM:1143
07:42:18.947 : X:0.00 Y:0.00 Z:0.00 E:0.00
07:42:18.990 : FIRMWARE_NAME:Repetier_0.91 FIRMWARE_URL:https://github.com/seemecnc/Repetier-091-ROSTOCKMAX PROTOCOL_VERSION:1.0 MACHINE_TYPE:ROSTOCK MAX EXTRUDER_COUNT:1 REPETIER_PROTOCOL:2
07:42:18.990 : Printed filament:0.00m Printing time:0 days 0 hours 0 min
07:42:18.999 : Begin file list
07:42:19.001 : End file list
Here is whats happening in commands before ever activating the home icon:
07:44:33.252 : N55 M105 *55
07:44:36.340 : N56 M105 *52
07:44:39.403 : N57 M105 *53
07:44:42.465 : N58 M105 *58
07:44:45.528 : N59 M105 *59
07:44:48.591 : N60 M105 *49
07:44:51.654 : N61 M105 *48
Hey Teoman,
I can move the carriages up and down. Just as before the unit was ever turned on. So I would say they are loose.
Hnm. Seems like your motors are not getting any power.
If you are certain the software is ok, check the power conncector of the rambo. Maybe a wire got disconnected while you were stuffing it back in to the bay.
If you have a multimeter you could try checking the fuses on the rambo.
Also. On the lcd, under printer settings there is "home towers". If you press that thrn we can be sure it is not a computer issue.
I agree. The last line on the LCD says ROSTOCK MAX read. Where is this home towers button located?
Nevermind... found it
It is not a computer issue.
The steppers are not getting power. So I am guessing this is stemming from a problem on Rambo
The big 15 fuse is intact, but it looks to me like there are at least two other smaller micro fuses on the board. WIll check these out.
Thanks again!
If you have a multimeter, check that all of the power pins on the right side are getting power.
How did you determine that they are in tact? With an Ohmmeter?
Yes... I checked the resistance on the large fuse, and pulled the two smaller ones. One of the little guys is bad or blown. I am fairly certain this is the problem. Before pulling them I was checking the voltage across the fuse, and when I placed the probes on the board I could hear the motors trying to activate. As far as checking the power pins.. what should I be looking for reading wise? Thanks for following up with me!!
I am concerned about what happened to this fuse... Not bragging, but my wiring/soldering is immaculate. I don't know where to get replacement fuses either, any suggestions?
This was recently covered.
Unfortunately i have no idea why the fuse burned. On the wires, you should check that they are properly fastened. And you can also check the voltage across the wires.
Although i have not needed to replace a fuse for myself (yet) i believe they can be purchased from Ultimachine. (Google the guys who make the RAMBo).
To save yourself now, you can solder a normal car type blade fuse on to the burnt fuse. If you search the forum you should be able to find a couple of images. You can go to your car and steal the cigarette lighter's fuse (or cigar lighter if it is a luxury automobile
) from the engine bay fuse box, it should be 10A if i remember correctly. There should also be spares there.
Lets see pictures of your immaculate wiring
I am not sure but you may be able to swap the fuses to check that that is indeed the problem. But as i said, you must check what that other fuse will disable and if they are the same size and rating. I am not that familiar with the rambo yet.
WIsh it was that easy... I got the parts on order check these things out... 5A fast trip... They are about the size of a grain of rice: https://ultimachine.com/content/fuse-0448005mr# I will follow p with some pics here in a bit
Search the site and you shall find...
[img]http://forums.reprap.org/file.php?4,fil ... download=1[/img]
Ahhhh!!! Hahaha the Magyver fuse!!
The fuses are available at mouser.com and digikey.com.
The original 5A fuse is
LittleFuse 0451005.NRL
The 10A version is
LittleFuse 0451010.NRL
The 10 AMP can be used in place of the 5 amp with no problems. The Rambo was designed to handle the 10Amp fuses.
The 10A version is
