EDIT: I was on Reddit/r/fixmyprint and it was recommended to "Since you've got a rostock, take advantage of the speed and set your z-lift to 1mm, fixes those snags on curling filament
[img]http://i.imgur.com/6ZDDPRs.jpg[/img]
Glad to hear that. Supports will vary depending on the Slicer you use so you may have to experiment with the different slicers.mpyr6 wrote:Thanks guys I will keep that in mind for future prints. I ended up just turning on supports and flipping it upside down. It worked well enough to use the shroud.
