Changing the Beeping Sounds
				tamcofarms
 - Prints-a-lot
I saw a video awhile ago where someone changed the beeping played when starting a print from the standard multiple beep to sound like R2D2.  Any clue or documentation as to how I could do something similar.  Mainly I figured if you could do it at the beginning with a 'tune' then you should be able to add some kind of fanfare to celebrate that the print job is done at the end.
						Re: Changing the Beeping Sounds
I am also now interested in such things.
Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
						Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
I would have figured you were the one with the R2 sounds to begin with!
							*not actually a robot
I take this as a compliment, and a fantastic one at that! Thank you! Lolbot wrote:I would have figured you were the one with the R2 sounds to begin with!
Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
						Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
				DarrenAnton
tamcofarms wrote:I saw a video awhile ago where someone changed the beeping played when starting a print from the standard multiple beep to sound like R2D2. Any clue or documentation as to how I could do something similar. Mainly I figured if you could do it at the beginning with a 'tune' then you should be able to add some kind of fanfare to celebrate that the print job is done at the end.
Here...
https://www.youtube.com/watch?v=ITXavSI ... ploademail
http://ddrboxman.github.io/RepRapRingtone/
http://arcadetones.emuunlim.com/arcade.htm
				IMBoring25
Every time I tried to change the frequency of the stock Rostock beep/buzz, the pitch didn't actually change.  I got it to do a few different variations of things that sounded like flutter-tonguing a brasswind instrument, but it was always at its core the same pitch.
