Extruder temperture
precisionpete
Extruder temperture
Post by precisionpete »
Going through the machine again to get printing I found a problem that I am not sure how to correct.
Hot end is E3D V6
Getting ready to print T-Glase with Bed at 60 C and Extruder set to 215C
Orion LCD panel reads set points correctly.
Bed goes to 60C and I measure within 1 degree with hand held non contact thermometer
Extruder temp with the thermometer is reading temperature exactly but in degrees F
So instead of 215C I am getting 215F
I know the thermometer isn't that accurate but it is close enough to tell me I have a problem.
Before I delve into the firmware for the hot end settings any thoughts?
Thanks,
Pete
Re: Extruder temperture
It sounds as if you have the wrong thermistor in your hotend.
Let the printer cool down so that every thing is a room temperature.
Hopefully you have a half decent meter that can read ohms.
The resistance of the hotend thermistor should be approximately 100K when you measure its leads with the ohm-meter.
Please report back with the value you read.
By the way the thermistor for the hotend should be unplugged from the Rambo when measuring.
precisionpete
Hi again :)
Yes I do have a good ohm meter. I'll take apart and measure.
Weird because apparently it was printing pla until I just updated the PID using matter control.
Forgot that important tidbit of info.
For info here was the old values and then new values I input after PID tuning.
Old:
P 31.36
I 2.18
D 112.9
New E3d hot end
P17.27
I 2.61
D 28.54
Not sure if that helps.
I'll take her apart and measure the thermistor ohms.
Thanks for the quick reply again Eaglezsoar.
precisionpete
Thermistor reads 100K ohms unplugged.
I still measure EXACTLY deg F on the hot end with the non contact thermometer instead of deg C.
Thoughts?
Thanks,
Pete
