Tall print, fairly large for ABS. Needs extra hot extrusion to help with layer separation.
First try, worked fine the whole way through, but I didn't like my infill or thickness settings, printed again.
Second time, extruder obviously got VERY cold (from 235 to 212) at a specific height and the layers just stopped sticking together.
Tried another time, different g-code, and same thing happens... at the SAME layer height...
It could be due to this part of the print jostling the head around a lot... maybe it's shaking a wire lose?
I got it to recover its temps by adjusting the bed temp down a bit and it helped....
Is this a power supply issue? Is my power supply failing intermittently? Is it a wiring issue at the hot end? (It looks fine... but it's covered in kapton)
Luckily I salvaged this print, it's been soooo perfect up until the near miss.
oops. I spoke too soon. The temp is back down to 210. The 14 hour print is at 92% if I lose this one I'm not going to be happy. I'm suspecting a failing PSU.
