help, my printer is posessed
Re: help, my printer is posessed
Max V2 has the extruder motor mounted up top, unlike your V1.  There exists the chance of crosstalk between the stepper wires, and the endstop wires on the V2s.
Oh, its a v1?  I missed that bit of info... also didn't know there was a difference there anyways
  Sorry about that!
well quite honestly I struggle thru with the electronics end of things, but if you dont mind spending a bit of time with me I would do my best to help you sort thru this problem. I would also make you go thru the things you have all ready went thru for trouble shooting purposes and even though you have all ready went thru them I would expect you to do it again and not just fake it and say yes its this. But you have to be willing to spend some time sorting this out and not just looking for a quick answer.
Lost pla castings? see me
DavidF wrote:well quite honestly I struggle thru with the electronics end of things, but if you dont mind spending a bit of time with me I would do my best to help you sort thru this problem. I would also make you go thru the things you have all ready went thru for trouble shooting purposes and even though you have all ready went thru them I would expect you to do it again and not just fake it and say yes its this. But you have to be willing to spend some time sorting this out and not just looking for a quick answer.
The joke about how many psychiatrists do you need to change a light bulb just came to mind,,,,,
Mac The Knife wrote:DavidF wrote:well quite honestly I struggle thru with the electronics end of things, but if you dont mind spending a bit of time with me I would do my best to help you sort thru this problem. I would also make you go thru the things you have all ready went thru for trouble shooting purposes and even though you have all ready went thru them I would expect you to do it again and not just fake it and say yes its this. But you have to be willing to spend some time sorting this out and not just looking for a quick answer.
I must have missed the punch line....
,,,,, Only one, but the bulb must want to change.
Oh great!! color changing bulbs!!Mac The Knife wrote:,,,,, Only one, but the bulb must want to change.
I finally watched the second video posted, and because of the sporadic movements, I'd also say that you may have some electrical crosstalking going on, just not up top.  I would suggest checking all the wiring down below, and isolate the stepper motor wires from the rest of the wiring.
If that doesn't work, see if you can convince someone to test your board on their machine.
				neorpheus0
 - Prints-a-lot
I have tried isolating the endstop/stepper wires from one another as best I can in the limited confines of the electronics bay with no apparent change in behaviour. I'm tempted to try throwing ferrite donuts on the endstop wires just to see if it makes any difference. Thoughts on this?
				dtgriscom
I have mixed feelings about this:neorpheus0 wrote:I have tried isolating the endstop/stepper wires from one another as best I can in the limited confines of the electronics bay with no apparent change in behaviour. I'm tempted to try throwing ferrite donuts on the endstop wires just to see if it makes any difference. Thoughts on this?
- That probably would kill any crosstalk between the steppers and the endstop wires (if you put the chokes near the RAMBo)
 - This really shouldn't be necessary if you're keeping the wires separate, but given the trouble you've been having...
Dan
				neorpheus0
 - Prints-a-lot
Well it's only a few bucks for a cheap pack of chokes from the regular places so i'm not really out anything if they don't work.  however i've never had to incorporate them into a build before so i don't know if there is some particular size or something i should be looking for.
				neorpheus0
 - Prints-a-lot
Well it turned out that the chokes didn't help at all, it was in fact a grounding issue causing the gremlins. at this point i should be ready for my first print but slice3r is generating some funky gcode. i mean the test cube looks right and everything but it is trying to print it centered on the edge of the bed between the X and Z towers. any thoughts of great oracles of the interwebtubes?
						- lightninjay
Check to make sure your slicer machine settings are configured for a round bed with 0,0 at center.
							If at first you don't succeed, you're doing something wrong.  Try again, and if it fails again, try once more.  Through trial and error, one can be the first to accomplish something great.
				neorpheus0
 - Prints-a-lot
Yup, i feel smart. it was in fact the printer bed settings. about to try for my first print, woohoo
						- lightninjay
Oh what a journey it's been!
Let us know how it goes!
Too many people solve their problems and fail to come back here and celebrate their victories with us all; instead they often end up just sharing their failures. We all like to appreciate the little victories here and there
				neorpheus0
 - Prints-a-lot
Haha ill be sure to share the victories when they come, but it looks like today is still not the day. something is still screwy with my PRINTER_RADIUS. the nozzle sits a touch further above the center of the bed than it should. it seems like changing the PRINTER_RADIUS value isn't affecting the nozzle height either. i'm lost...
