My build went fine. Good instructions for sure. However, the PSU with the printer tripped me up the last couple of days. As others on the forum seemingly discovered, the Diablotek 600W power supply I recieved was not up to the task. I replaced it with a Corsair CX750M (750W), which someone else had suggested. I've just finished installing that, and I've started PID autotune...
A quick question on autotune and MatterControl's terminal window:
When I attempt to do autotune, I continuously get temperature readouts in the terminal, which are noise and make it difficult to get the data I need. The screenshots from the Rostock v2 build manual don't seem to have this output, so I'm guessing there's some way to disable it? To clarify, I see output like this in the terminal:
<-T:106.32 B:36.07 B@:0 @:255
<-T:106.19 B:36.07 B@:0 @:255
<-T:106.13 B:36.07 B@:0 @:255
<-T:106.23 B:36.07 B@:0 @:255
<-T:106.54 B:36.07 B@:0 @:255
