teach me please
darkjorik
teach me please
Post by darkjorik »
teach me please
How to print without computer.
I cant find this info in manual.
jram
Re: teach me please
Post by jram »
One way to do it once your computer is connected via Matter control
Import "Add" STL to matter control
View the part.. Edit if needed
Export as G code then save to SD card
SD card slot is on left hand side of LCD panel, you can then select a file from the SD card
Re: teach me please
I use Cura to slice, and when you're done with a slice, you can save the GCode directly to an SD card from the main page.
Insert SD card into a printer that's on, and it opens the print from SD dialogue automatically.
Save to card, insert card, select file, profit.
darkjorik
Re: teach me please
Post by darkjorik »
I'm finished MAX 2 printer. Thanks. Now I can print without PC. :D Print some simple models.
What next ?
How to build own model :?:
Return to “Rostock MAX v2”
