.stl file for spool upgrade ?
i have a trouble.
In Ukraine filament made with cardboard spool. It's no good for MDF spool holder.
No slip. Cardboard spool can be damaged.
Maybe some one can give me .stl file for spool upgrade ?
Re: .stl file for spool upgrade ?
This fits over the stock arm and provides a smooth surface that should work for cardboard spools.
http://repables.com/r/204/
I found that model a few weeks ago. Honestly, that should be everyone's third print, right after the two fan shrouds!
this is joke ?
look like impossible print.
Who made this ?
i try print whith glue stick and skotch.
There is not good idea.
Too little space on the bed for too big model.
Who made this ?
Print it standing on end.
Yeah, you have to pick the right end though too.
One of the ends has a 90 degree corner. That's the bottom. The other end has a curved corner. That's the top.
How i can rotate model ?
Are you using MatterControl? There should be an Edit button somewhere once you load the model. It has controls for rotating.
I'm use MatterControl 1.2
when i push the Edit i see : Export, Copy, Remove. Nothing more
I found this button in a view section.
Can I build this model with ABS or i need PLA ?
- Captain Starfish
ABS would be my preference, but either should work fine.
