First print!
hubrigant
First print!
Post by hubrigant »
After about 35 hours of work, I finally got my PEEK fan shroud printed, and on the first try, even!
To me, it looks as if it printed out fairly well for a newbie's first attempt. I see some goobers here and there (overextrusion?), but the part looks like the part, and the first layer looks pretty smooth. The print was done with MatterHackers Pro-series white ABS 1.75mm
Is there anything that I should be looking at adjusting based on these pics?
Interesting goobers on the arms
PEEK fan shroud, first layer visible on top
Re: First print!
Post by Mac The Knife »
I would just double check the cheapskate adjustments, and print some more. Practice makes it better.
hubrigant
Re: First print!
Post by hubrigant »
I'll check the Cheapskate adjustments. I'm curious, what in the print indicates that they might be out of adjustment? The slop near the corners?
Re: First print!
the waviness of the vertical perimeters. Also, If it was your first print, the wheels tend to seat in a little bit.
jram
Re: First print!
Post by jram »
+1 on the cheapskate adjustment. I went back after my first few prints and re torqued any screw I could get to as well. I found that I was a bit light handed during the initial assembly process. It still feels great to get that first print out after all of the invested hours!
hubrigant
Re: First print!
Post by hubrigant »
I went through and checked all of the Cheapskates. They seemed OK to me, so I did some more looking and discovered that the Z-tower belt tensioner had slipped down to the bottom. I retensioned that tower and printed out the PLA fan shroud, which looks better.
Return to “Rostock MAX v2”
