So I want to edit the configuration.h from my rostock, but apparently im clueless about how to get in to it, if its not from scratch uploading a file off my PC>
The original file i downloaded is long gone, so its only flashed on the eeprom.
Is there any way to get the config loaded in to arduino directly? without the file and edit it? or is there a way to pull it off of the eeprom, edit it and then push it back?
thanks in advance
Reading COnfiguration.h from Rostock SOLVED
Re: Reading COnfiguration.h from Rostock
nevermind, i wiped it on accident... gotta start over
i HATE bed leveling and all that stuff
i really hope i can just set my Z height and everything else will be good to go... i think i can remember what my horizontal radius was... i hope
ok, boy did i get lucky, i remembered my exact horizontal radius and after setting z height, everything was perfect...
Re: Reading COnfiguration.h from Rostock SOLVED
quick question... im printing now and everything is good... but im finding that the head moving to the bed at the start of the print is VERY slow... did i miss putting a setting back in? it used to fly down to the bed quickly and get the print started... not a huge deal, but different than before i wiped my rostock haha
- lightninjay
That probably has to do with your slicer. If your slow speeds are from a file sliced with Craftware, that's probably just that I set a slower Z speed than you're used to.
Are you using repetier host?
its just gcode that is in craftware... i found where to edit it
thanks
thanks
