Rambo fan location?
Holy1
Rambo fan location?
Post by Holy1 »
I am messing around with the rambo and wondered if the fan is located where it is for a reason. Would a fan blowing on the top of the board be OK? I wanted to use a larger diameter / quieter fan.
Earthbound
Re: Rambo fan location?
Post by Earthbound »
The biggest source of heat on the RAMBo is the driver chips for the stepper motors. The chips are designed to use the circuit board as a heat sink, so the most effective means of reducing chip temp is to cool the backside of the board. Cooling the front without cooling the back might even cause problems.
Holy1
Post by Holy1 »
Earthbound wrote:The biggest source of heat on the RAMBo is the driver chips for the stepper motors. The chips are designed to use the circuit board as a heat sink, so the most effective means of reducing chip temp is to cool the backside of the board. Cooling the front without cooling the back might even cause problems.
Thanks Earthbound.
bot
Post by bot »
This is what I did for mine. It has worked great so far. After over 325 hours of printing, not a single heat issue related to the PSU, the Rambo, or anything down there. http://forum.seemecnc.com/viewtopic.php ... 584#p51072
*not actually a robot
Holy1
Post by Holy1 »
I'm not using the Rambo on a Rostock, although it was harvested from one. I am making a case to enclose the Rambo and LCD.
bot
Post by bot »
Oh, cool.
