Failed skate bearing, squeaky tower
jesse
Post by jesse »
The Z-tower on my Rostock Max was making an annoying squeak noise. I tried adjusting the tension on cheap skate but that didn't help. The bearing was easily removed by unscrewing one screw. After removing the bearing holder, the bearing made a grinding noise when moved. I had a spare from inline skates and installed it. It worked fine after that.
I've been using the printer for about two years now and this was the first mechanical problem.
Re: Failed skate bearing, squeaky tower
jesse wrote:The Z-tower on my Rostock Max was making an annoying squeak noise. I tried adjusting the tension on cheap skate but that didn't help. The bearing was easily removed by unscrewing one screw. After removing the bearing holder, the bearing made a grinding noise when moved. I had a spare from inline skates and installed it. It worked fine after that.
Not bad after 2 years. 1 part in two years seems to indicate high reliablility.
Return to “Rostock MAX”
