I've been fiddling to see if I could improve the noise damping.. well after testing by releasing the stepper motors in Repetier and testing each tower independently (homing it) it turns out that ALL of the stepper motors contact the case plates on an Orion with the Astosyn dampers in place (Well on mine they do).
So on an Orion Delta you'll need to space out both the cold end plate & the filament roller plate from the main body of the machine. I used a couple of printed washers on each plate for a temporary solution but the preferred option would be a complete gasket about 2-5mm thick so the motors don't touch these plates.
So basically all the noise if from the Feed stepper now.. offsetting the cold end backplate doesn't help with that so a gasket will have to be made up at some point.
Stepper motor dampers don't seem to be working
RocketMagnet
Re: Stepper motor dampers don't seem to be working
Not sure I understand EXACTLY which face contact you mean, but for isolation "washers" I urge you to consider simple rubber grommets.RocketMagnet wrote:I've been fiddling to see if I could improve the noise damping.. well after testing by releasing the stepper motors in Repetier and testing each tower independently (homing it) it turns out that ALL of the stepper motors contact the case plates on an Orion with the Astosyn dampers in place (Well on mine they do).
Thick, cheap, readily available, etc.
A potential problem could be in getting a group of them all squeezed to the same pressure - you can usually count screwdriver turns for this (-:
Be sure to put a metal washer under the screw head - and maybe another one between the grommet and whatever the screw goes through.
- jdurand
If you can reach, slide a metal spacer under all 4 sides. Tighten screws until snug against the spacers, then loosen each just enough to pull out the spacer.
RocketMagnet
Regb... No im talking about on an Orion with the Dampers in place the backs of the stepper motors touch the outer casing.
The spacers im on about are simply spacing out the bolt on side panels so they don't touch the backs of the motors.
Ahh, yeah I guess that would buzz and rattle a bit.RocketMagnet wrote:Regb... No im talking about on an Orion with the Dampers in place the backs of the stepper motors touch the outer casing.
You have probably fixed this by now, so what I am about to type may be too late.RocketMagnet wrote:Regb... No im talking about on an Orion with the Dampers in place the backs of the stepper motors touch the outer casing.
For others doing this, I found some "half height" NEMA 17s here;
https://www.lulzbot.com/products/half-h ... pper-motor.
This may not work out for you in UK, but a 3 pack of these for ~$40 could save others some hassle.
- bvandiepenbos
RegB wrote:You have probably fixed this by now, so what I am about to type may be too late.RocketMagnet wrote:Regb... No im talking about on an Orion with the Dampers in place the backs of the stepper motors touch the outer casing.
Hmmm, I would think those short motors would not have enough torque, looking at the spec sheet here
http://devel.lulzbot.com/TAZ/accessorie ... 033067.pdf
Says they have 26 N cm of torque, If I converted it correctly that is only 37 oz in ... I think the SeeMe motors have 60-70 oz in
So I do not think they will work for the X Y Z motors?
Thanks Brian,
I should have admitted to not having checked specs.
Lulzbot suggest them for extruders, though I don't now through what gearing.
BTW I haven't done the f=ma arithmetic either, but maybe my super light trucks need less f to a them.
RocketMagnet
Yeah I'd looked at Astrosyn as they do various sizes and are UK based.
http://astrosyn.com/section.php/61/1/my17hdn_series_1_8
But as far as I can tell the smaller body ones many not have enough Torque.. 39mm body are 230-420 mNm compared to the ~48mm (same as fitted to mine) are 300-580.
No idea if 230-420 is enough for the XYX?
I've essentially discovered why my feed is really noisy in comparison to everything else, the bolt on MDF is cracked right through that the cold end mounts to, so that's where the loud rattily and worsening noise is coming from. It's only being held together by the surface laminate.
I've contacted SeeMeCNC and sent them pics to see if it's possible to get a replacement plate.
