[resolved] thermistor got off
- jeffhuber
A print came loose off the bed and got all messy in my e3d hot end. I printed another print after just fine. Now the machine has cooled down but the thermistor says the hot end is hovering around 212c when it is obviously cold (around 33c). Thoughts on how to fix this?
							Rostock max v2 with e3d v6
Re: thermistor got off
You most likely have a short somewhere, probably between the thermistor and the heater. First thing to do is to disconnect them from the Rambo board and measure the resistance of both. At room temperature the thermistor should be about 100KOhms and the Heater about 3Ohms.jeffhuber wrote:A print came loose off the bed and got all messy in my e3d hot end. I printed another print after just fine. Now the machine has cooled down but the thermistor says the hot end is hovering around 212c when it is obviously cold (around 33c). Thoughts on how to fix this?
						- jdurand
And NO connection between them or to ground.
- jeffhuber
Re: [resolved] thermistor got off
half of the thermistor wire had completely sheared off. strange. anyways - i replaced it with a backup i had and all seems good to go
