Check and double check.
[email protected]
Post by [email protected] »
After hours of bad results during extensive calibration process, I found an embarrassing problem. I was in the middle of a 20mm hollow box print and I went to get another hard cider and I bumped the table the printer is on as I went by. I came back and found my part was now printing at a slight angle...WHAT THE... I started to investigate and found that I could move the xyz towers around slightly causing visible changes in the part. I popped the plex covers off and sure enough the allen head bolts that clamp the aluminum towers were finger tight, top and bottom. I remember getting these tight but I store my printer in a much colder area then bring it into a warm environment when I am home :oops: and I think this may have contributed to this problem.
Max 2
xyz DaVinci 1.0 with custom FW for Repetier-Host
Future plans
NextEngine scanner
Droplite or other SLA
Re: Check and double check.
It's always relieving to find the culprit though. It's the problems with no smoking gun that really suck.
Hope your next prints are awesome, good luck!
