Captain Starfish wrote:Only the sort of PCBs that you could knock out with a Dalo pen and bottle of ferric chloride, by the looks of it. Doesn't look anywhere near the resolution required for 10 thou tracks with 5 thou separation.
Still, it's an approach that holds promise if it's refined - wouldn't it be nice to print multilayer boards with printed solid vias rather than having to drill, coat, plate, tin and mask to get the layer to layer contacts working.
I decided to spend more on components with integrated PCBs and easy wiring (I2C and SPI for example) because I don't want to get into all that stuff. I have a CNC router at home so I can mill my own double-sided PCBs, but I'd just as soon let that be someone else's problem - pay more in order to worry less.
This kind of printer would be perfect for some of the projects I've worked on. Microcontroller here, input device there, output device somewhere else, and I wouldn't have to strip wires or solder them to anything. I could print everything into a solid object that gets thrown away if anything malfunctions, or I can use a backplane design, where things plug into a bus - a
printed bus. Probably with those little springy metal things that are put in contact with metal pads, the ones they use for solderless connections between components and PCBs. No solder fumes, no "ick I'm touching lead with my bare hands" feeling, no having to get out the little filter-fan I use to clean (some/most?) solder fumes out of the air. I could have four layers, eight layers, weird shapes, etc. and everything comes out as a finished product. Everything would always be printed the same. I'd never have to worry about accidentally soldering something wrong, shorting Vcc to ground, accidental solder bridges, etc. I'd still have to verify the alignment of components, but at least the possibility of mis-routing a wire would be gone.
