Hi guys! After reading about the trouble a lot of people have about getting print off of PEI, I wanted to share a trick I discovered while puzzling it myself. All you need is a pair of diagonal flush cutters, which most electronics folk use for cutting component leads after soldering. All you do is use the flush cutters to pry the piece up at a corner like so, then use a spatula to peel the rest of the part of. Easy
http://imgur.com/gallery/95Yj2
