First Print sucess - few questions
robo_cobbler
Post by robo_cobbler »
This is my first foray into 3D printing. Finished building a Rostock Max v2, and finally got it calibrated and printing. Just made my first print, the fan shroud, as per the manual. See pictures below. I must say, I'm quite impressed. I really didn't expect it to work this well on the first try. Props to the SeeMeCNC folks for putting together a great printer and such a thorough manual. As you can see from the pictures, there are a few defects in the ABS print. I'm wondering what might be causing them and how I might prevent them. Is there a guide somewhere that lists common defects and potential solutions? Many thanks.
[img]http://i.imgur.com/m819s9yh.jpg[/img]
[img]http://i.imgur.com/aKDCUPlh.jpg[/img]
[img]http://i.imgur.com/A67yS8Ah.jpg[/img]
[img]http://i.imgur.com/7tgOTWuh.jpg[/img]
Re: First Print sucess - few questions
Your print does not really look that bad for a first print. The artifacts that you are seeing are quite common and as you continue to print parts, adjust the slicer settings and see what effect the changes make.
Also reading past threads about bad prints could benefit you. In your browser address bar put in site:forum.seemecnc.com bad prints
