E3D Temperature 140 C Plateau
dct16
Post by dct16 »
Gentlemen,
New V2 purchase, immediately upgraded to E3D hot end. When doing PID autotune, the hot end will only reach 140 C, where it plateaus. Ultimately the autotune times out and fails. Any ideas what could be causing this? I'm sure it's something simple. Checking with an infrared temp gun shows that the thermistor is relatively accurate.
I appreciate the help.
jdurand
Re: E3D Temperature 140 C Plateau
Post by jdurand »
Check your power supply voltage with the heater on.
DavidF
Post by DavidF »
somewhere on here there is a tread about the ohms of the heater cartridge. At one time there was some that were not the 40 watt that they were supposed to be.
Lost pla castings? see me
dct16
Post by dct16 »
Voltages are 11.5-11.6 at power supply, to hot end and to cooling fan.
I have done PID autotunes at 125 and 135 degrees, and while values changed, they didn't increase top end temperature.
KAS
Post by KAS »
It's a long shot but what's your Extr.1 PID Max Value set at?
You might have to lower it before running the auto PID then raise it back to 255 and try again.
edit: I guess raise it if it's not at 255 in your case.
dct16
Post by dct16 »
Set at 255...
I thought it obvious, but it's worth mentioning that I cannot get the hot end over 140 with manual controls either.
KAS
Post by KAS »
just for shits and giggles, change the max to 128 and run autotune.
Just an odd number and appears to be consistent on the graph
KAS
Post by KAS »
or try it in mattercontrol to see it it's software related.
dct16
Post by dct16 »
Okay. So something changed, which is progress.
When PID Max is set to 128....hot end maxes out at 82 C
Already changed to mattercontrol as well..
KAS
Post by KAS »
any luck?
JFettig
Post by JFettig »
do you have the correct thermister called out in the firmware?
dct16
Post by dct16 »
Followed these directions and uploaded to EEPROM in Arduino:
#define EXT0_TEMPSENSOR_TYPE 8
teoman
Post by teoman »
Can you measure the resistance of your resistors?
rpress
Post by rpress »
If I had to guess I'd say you have a resistor meant for 24V.
dct16
Post by dct16 »
46 Ohms
dct16
Post by dct16 »
That's at the board and the resistor independently
DavidF
Post by DavidF »
If im not mistaken a 40w heater cartridge should ohm out at 3.3 ohms....
dct16
Post by dct16 »
4.6 rather...pesky decimals
DavidF
Post by DavidF »
dct16 wrote:4.6 rather...pesky decimals
That would put you around 30 watts... hmmm. Now ill have to scratch my head a bit and think about it..
DavidF
Post by DavidF »
Ok process of elimination time, have you tried to hand feed some abs thru? This would help verify your temp gun.
Second wire in the stock hot end and thermistor (reselect default thermistor #?) And rule out the heater and thermistor.
Also thinking switch wireing to extruder 2 on the rambo and see if its the same problem. Dont forget to select the right thermistor...
dct16
Post by dct16 »
Okay, I was going to start with manually extruding ABS. I went to manually heat up the extruder, set it to 235 and it plateaued at 40 C this time. I found that very strange and went to look at my EEPROM configuration in MatterControl. Extr 1 PID Max was set to 44...so I reset it to 255 and clicked save. Repeated manual heat, plateaued again, went back and it was set to 39. Repeated process and its set to 34. Will wire in stock hot end now...
DavidF
Post by DavidF »
Sounds like you found your bug all ready...
dct16
Post by dct16 »
Hooked up stock hot end and there seems to be no problems. Went up to 200 C on autotune with no hesitation.
dct16
Post by dct16 »
I'm thinking that there has to be a problem somewhere in the firmware settings, but I've gone over them time and time again...
Any suggestions would much appreciated.
DavidF
Post by DavidF »
ok try putting the stock thermistor on the e3d and see what happens....
