I have installed it on Beaglebone Black and it is looking very nice.
I had 0.50.3 it first and had not quite got it configured completely. The newer version seems to be working well so far and I think I have got it fairly well set up.
Repetier-Server 0.51.0
Bob
Delta's are the way!
Re: Repetier-Server 0.51.0
I did a print job completely by remote this morning.
I had to go shopping so I setup a job and made the gcode file, I then imported the gcode to the beaglebone and told it to print. Went down to the shops and took the iPad and when the jobs was done it sent a message to mail system that the print job was finished (repetier informer).
Still a little more to do, I'm waiting for a USB lan device to come and I will configure a link to a camera and also the real Internet soon.
I did have some problems with temperatures but a wiring tidy up fixed them
it is spot on now!
Bob
I just installed repetier-server on a banana pro. But for some reason the interface sucks. Not quite sure what is wrong.
I can connect to it on my local network. And it can do some changes but if the interface is going to be like this, I really prefer not to invest any time in it.
Also would you mind sharing your configuration file? Or does seemecnc have an official configuration file?
Thanks in advance.
EDIT: Never mind. I rebooted and it is looking good now. But I would still appreciate a config file.
Thanks in advance.
I have taken it down and now I have it running on a Raspberry pi 2 and it is now perfect. Still have to get the camera working, I have a medical thing to do first and then
Bob
OK, I got it working.
Connecting to the printer over WIFI is nice
Now to design an enclosure for it.
Glad you have it working now
Mine is running on Raspberry Pi 2 with wifi and the best thing is it is no longer tied to my Mac. It is presently making a two tiered spice rack better than 20 hours, see if it hacks that..
Bob
I am not sure if it is the model or someth8ng else but i did get some micro pauses 5 10 times during the firat print i made. They lasted only a second or less.
Will know more later.
