Power Supply?
VTOLmotors
Power Supply?
Post by VTOLmotors »
My power supply does not seam to have the 6 pin as shown in figure 3-17. These are supposed to be for the RAMBo board. What do I do?
Earthbound
Re: Power Supply?
Post by Earthbound »
You can get the yellow and black wires from any remaining connector. Gene used that particular one because it was convenient having only the colors needed. I'd use the thickest yellow and black wires that haven't been utilized in the earlier steps.
VTOLmotors
Re: Power Supply?
OK, thank you. I will try that.
VTOLmotors
Re: Power Supply?
So there are groups od black yellow and black red. Is red the same as yellow or does it have to be yellow?
Re: Power Supply?
Post by Mac The Knife »
Black is common. Yellow is +12 volts and red is + 5 volts. Use the yellows.
teoman
Re: Power Supply?
Post by teoman »
You may have problems if you use red.
But keep a couple of red black and yellows handy. You may want to attach stuff like LEDs etc later on.
