Has anyone set up auto bed tramming (leveling) using an inductive sensor?
[youtube]http://www.youtube.com/watch?v=EcGFLwj0pnA[/youtube]
I bought the sensor and will probably try to get it working on 12v. Then try to get it working with Smoothie 3d printer firmware.
Setting up auto bed tramming leveling tilt compensation
Re: Setting up auto bed tramming leveling tilt compensation
I know it's been talked about. The inductive sensors, pressure sensitive resistors, IR, ultrasound, LiDar, mechanical z-probes, etc. A few of us were scheming about using an accelerometer to detect when the hot-end itself lightly taps the glass.
Fortunately, after you get your bed level you've good to go and the adjustments usually stick pretty well.
It doesn't work with PEI or a glass bed on top of the heated bed. The sensor needs to be really close 1 or 2mm.
I have Done it using Inductive sensor 12VDC (Working voltage 6VDC~36VDC). Search DELLTA-1 and you will find the thread. I am using RAMPS1.4 with Marlin Firmware, i dont know how you will do it,,...
