First Calibration Issue
3amjosh
Post by 3amjosh »
I'm doing my first calibration on the end stops. The machine is stock pieces. I've set the Z home. When I go to the Z Tower first, the paper won't touch the nozzle, it's just above it. The instructions indicate to "lower the platform" or "raise the platform" which is insanely confusing to me since I'm not touching the platform. When I adjust the screw on the Y Tower Adjustment Macro, the nozzle crashes into the build plate. I've loosened the screw a good bit and still having the same issue. I'm afraid If I keep trying I'm going to break my nozzle.
mlapaglia
Re: First Calibration Issue
Post by mlapaglia »
The platform is referring to what holds the hot end, the part that moves across the build plate. If the nozzle is not touching at the Z tower, then move the endstop screw on the Z town in. If it is touching too much move the Z screw out. If you're going from not touching to then crashing into the bed you are turning the screw too much.
This video covers the process
http://youtu.be/Oe3qQcgMsZw
It was poser on SeeMe's Twitter a couple of days ago.
Kevinvandeusen
Post by Kevinvandeusen »
Turn screw 1/8 of a turn at a time
DavidF
Post by DavidF »
Polygonhell wrote:This video covers the process
Just watched the video. I think I like the old way of doing things better thru repetier host....
Lost pla castings? see me
