Hi there,
I'm having the problem that my hotend temperature is inconsistent at high levels used for ABS printing. For example if i set 232 °C it will stay at around 228, if i set 228 it will stay at around 225. It is not very stable, there is too much fluctuation compared to when i use the hotend for PLA printing at 190 °C.
I've freshly recalibrated the PID values using M303 S200 as stated in the Manual.
Now since S200 specifies the temperature i was wondering if maybe i should redo this PID Calibration for a higher temperature, like 230°C?
Hotend Temperature inconsistent at high levels
Re: Hotend Temperature inconsistent at high levels
Yes, ideally you should calibrate it for the exact conditions you will use it at.
Some even do the calibration while extruding which cannot hurt.
