Desiccant Opportunity?
KAS
Post by KAS »
OUT OF DESICCANT AT THIS TIME Fri Mar 20, 2015 4:35 pm, I'm expecting a while till I receive more in.
What I’m purposing for those interested is stuffing a flat-rate USPS (US only, sorry) boxes full of 4 unit Tyvek desiccant packs.
This is mil spec MIL-D-3464 Type II if you would like to know the exact details.
I’ll include a couple of humidity indicator cards that measure 30/40/50% humidity. These desiccant packs can be rejuvenated
unlimited times by following the instruction printed on each bag. As a warning, Tyvek bags melt very easy so don’t try to
speed up the process by using too much heat.
What it comes down to is we do not reuse or reactivate old desiccant, we trash them. Only new packs go back into our…, let’s
just says end product…
If this is something that people are interested in, I’ll run to the post office and grab the flat rate boxes. You are paying the cost
of shipping only (maybe paypal fees, not sure what that would be). I’m not looking to make any money off this.
Let me know below if interested, and I’ll make it happen.
Pricing for shipment, plus paypal fee.
-Small Flat Rate Box 6 packs, 2lbs.6oz $6.95 ( not worth it )
-Medium Flat Rate Box 29 packs 11lbs, $13.65
-Large Flat Rate Box 48 packs, 18lbs $18.90
Tracking list:
Fri Mar 20, 2015 4:37 pm
precisionpete - 1 Large (paypal Sent)
mvansomeren - 1 Large (paypal sent)
These just came out of service today. Dumped them on the ground for the pic, but going back in the sealed container.
Doing a quick test to see the life left in the desiccant. See the 30% turning on the left? I put one tablespoons of water and microwaved for 20 seconds. we do this to verify the packs can absorb the moisture in 24 hours.
6oz each, not sure the weight of a small or medium flat rate box.
I'll toss in a couple cards in case you have multiple containers
nitewatchman
Re: Desiccant Opportunity?
Post by nitewatchman »
Very interested in as much as you can spare!
Flat rate sounds good, let me know and I will sent doubloons!
AndyB
Post by AndyB »
Also interested in 8 packs. PM me and I'll send you some coin.
KAS
Post by KAS »
Sounds good. I just picked up three different sizes of boxes. Let me pack these and post the weights estimate of quantity inside and the flat rate shipping cost.
KAS
Post by KAS »
Small Flat Rate Box 6 packs, 2lbs.6oz $5.95 .99ea
Medium Flat Rate Box 29 packs 11lbs, $12.65 .43ea
Large Flat Rate Box 48 packs, 18lbs $17.90 .37ea
The quantities are estimates, I'm just going to toss them in till it's full.
Paypal charges a small percentage fee + .30 let's just make is a buck and be done with it.
The small box isn't worth it IMO. Yes that's a lifetime of jerky desiccant packets, but com'on...
also, I'll place everything in plastic bags so they don't soak up the rain/snow when USPS kicks them to the door.
PM me your paypal email and what box, I'll send an invoice and drop these in the mail the next day.
hard to read but it's 18
6 packs is pushing the limits of that box
KAS
Post by KAS »
1 Large Sold,
1 Large Reserved for nitewatchman.
eek, I need to see how many boxes I can fill :shock:
BenTheRighteous
Post by BenTheRighteous »
Any chance of you taking bitcoin for payment? :)
I'll PM you my PayPal email to reserve a spot anyway. I definitely want in on this!
KAS
Post by KAS »
BenTheRighteous wrote:Any chance of you taking bitcoin for payment? :)
nope, no bitcoins. :cry: Sold 47 bitcoins about 3 years ago and I'm still kicking myself in the ass.
I'll send the paypal invoice right now.
KAS
Post by KAS »
3 sold, I have enough for 1 large box tonight, plus the one on reserve for nitewatchman.
I'll grab more on Tuesday when i get back to work. Just post here if interested that way I know about how much to grab.
Eric
Post by Eric »
Put me down for a large box. PM incoming.
Are the indicator cards reusable as well, or are they trash once they turn pink?
jdurand
Post by jdurand »
Depending on what the bags are made of, you can bake/microwave pretty much any desiccant to dry it out. If you bake it you need a convection oven that vents the moist air so it doesn't just suck it back when it cools.
bvandiepenbos
Post by bvandiepenbos »
I will take one large box.
thanks
I will pm my paypal email
precisionpete
Post by precisionpete »
I'll take 2 large boxes.
PM inbound.
Much appreciated this kind offer.
KAS
Post by KAS »
Eric wrote:Put me down for a large box. PM incoming.
Yes the cards are reusable (unless they physically get wet, the dye runs). A hair dryer works best to turn them blue again.
KAS
Post by KAS »
jdurand wrote:Depending on what the bags are made of, you can bake/microwave pretty much any desiccant to dry it out. If you bake it you need a convection oven that vents the moist air so it doesn't just suck it back when it cools.
The 4 unit bags above are made of Tyvek. Hard to explain but it's the same Tyvek moisture barrier they wrap houses in. Any conventional oven will work, just keep the temp low. The reactivation time listed on the bags is 16 hours at 245F. That's a long time to be running an oven, so I messed around with different direct and indirect temps and all failed. Either the bags would melt or the seals on the edges of the bags would come unglued. I tried to microwave on high and the bag doesn't allow the pressure to escape fast enough. The pressure turn the bag into a ball in a hurry then melts at the seams. Maybe a defrost or lower power setting would work. I haven't tried drying these with a gas type oven.
As a suggestion, use a cookie sheet and place a layer of foil over the top. Ovens have a tendency to over heat then turn off to maintain the desired temp.
KAS
Post by KAS »
I'll update the first post as I get more request below.
mvansomeren
Post by mvansomeren »
What about using a food dehydrator? I have one with multiple levels that I use to make beef jerky. Do you think that would work?
MKGrinch
Post by MKGrinch »
I will bite on this one! 1Medium box Please!!! PM Sent! Thank You!!
He Who Dies With The Most Toys Wins!
BenTheRighteous
Just wanted to chime in that my large box arrived today, thanks Kas! It was totally filled to the brim. My wife is probably going to look at me funny when she finds out about this, but I ordered some jewelry for her today so I'll be good for awhile! :lol:
KAS
Post by KAS »
Glad you got it. Kentucky got hit with that snow storm and we haven't had mail/school, more importantly UPS service in a week. They even closed where I work which means I'm on hold for desiccant.
Curious with the cold and old packs, what color was the indicator cards?
Eric
Post by Eric »
Mine arrived a few hours ago as well. Can't give you a cold test, as the local temperature is about 70 F today. Indicator card shows pink on 30%. 40% looks lighter than 50%, but still purple.
KAS
Post by KAS »
Okay, just be careful with reactivating them. That tyvek melts pretty easily or you'll loosen the glue that seals the ends and dump that stuff everywhere. The indicators cards will turn back blue in about 30 seconds of high heat under a hair dryer.
I asked about the cold because it will give you a false negative. The desiccant packs retain the moisture at lower temps and the cards will not detect the correct humidity until the temp raises.
JFettig
Post by JFettig »
I'm interested in some.
Would it hurt to dump the desiccant out of the packages? I'm storing my filament in a 5 gallon pail with a gamma lid and I thought about spacing the filament from the bottom and fill the bottom with desiccant.
You could then reactivate the desiccant easily without worry about the tyvek?
How soon until you think you'll have more? I'd take a medium flat rate box full.
KAS
Post by KAS »
JFettig wrote:I'm interested in some.
I'm expecting Monday, and believe I have enough to cover those who wanted some including you.
To be honest, getting rid of the bag might be the best way to go. Let me get one of mine and cut it open. I'm thinking it's the Montmorillonite Clay based desiccant, we don't use much silicate type desiccant anymore because of cost.
KAS
Post by KAS »
It's clay for sure.
Here is the MSDS for the pack, looks mostly inert except for the abrasive dust and Silica, Quartz. Just be safe :)
http://cdn2.hubspot.net/hub/391128/file ... 2408120447
Return to “The Lounge”
