Is there some trick to this? All my extrusions are slightly angled inwards, if I get one square the other two are worse. is there any other spots to work with possibly besides the tslot? I'll post some quick pix.
Thanks,
Doug
squaring extrusions to bed
Re: squaring extrusions to bed
How flat should the heated bed be?
I haven't read the manual in a while, are we still squaring the towers to the base before heat bed installation? I don't see the top of the printer but make all your tower adjustments before you put the top on else it will cause more headaches.
