No control over printer?
Felix
Post by Felix »
I have finished building the Rostock MAX and have moved to start doing a dry run while my hotend is curing. However I am having problems with getting anything to move correctly.
I have installed/downloaded all the necessary software and whatnot. Repetier is communicating with the RAMbo albeit with errors. The 3 axis all home properly if done individually or the allhome button on the manual control. The problem comes in when I try to do anything else, be it moving an axis in either direction, moving the extruder motor, or even test heating the bed. Anytime I hit one of the buttons or type the gcode command for them it just returns the message "Printer stopped deu to errors. Fix the error and use M999 to restart! (Temperature reset. Set temperature before restarting). Even when I try to do just a dry run it just spams the log with that message.
Ive gone over my wiring several times now and haven't seen any faults with it. Like I have said the steppers move up and down to do their home and the endstops work correctly as well. I've looked through the setting in repetier and see not differences in mine vs the settings in the Guide.
here is some example logs just to show what is going on, maybe it explains some things a little better than I did:
19:40:32.510 : OpenGL version:4.3.0
19:40:32.511 : OpenGL extensions:GL_AMD_multi_draw_indirect GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_texture_type_2_10_10_10_REV GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_OES_compressed_paletted_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_point_size_array GL_OES_point_sprite GL_OES_rgb8_rgba8 GL_OES_read_format GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
19:40:32.511 : OpenGL renderer:GeForce GTX 460 SE/PCIe/SSE2
19:40:32.511 : Using fast VBOs for rendering is possible
19:41:31.470 : start
19:41:31.470 : echo: External Reset
19:41:31.470 : Marlin 1.0.0
19:41:31.470 : echo: Last Updated: 2012-09-21 | Author: johnoly99 and johnnyR from UltiMachine
19:41:31.470 : Compiled: Mar  3 2013
19:41:31.470 : echo: Free Memory: 1860  PlannerBufferBytes: 4928
19:41:31.470 : echo:Using Default settings:
19:41:31.699 : echo:Active Extruder: 0
19:41:31.706 : FIRMWARE_NAME:Marlin for Delta FIRMWARE_URL:https://github.com/johnoly99 MACHINE_TYPE:RostockMAX
19:41:31.715 : Error:0
19:41:31.715 : : Extruder switched off. MINTEMP triggered !
19:41:31.715 : Error:Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:41:31.715 : echo:Unknown command:"or"
19:41:31.719 : Error:Line Number is not Last Line Number+1, Last Line:4
19:41:31.719 : Resend:5
19:41:59.908 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:42:02.096 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:42:03.063 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:42:03.521 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:42:04.976 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:42:05.463 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:47:00.902 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:47:01.418 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:47:01.866 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:47:02.467 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:47:02.865 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:47:28.399 : <Slic3r> => Processing triangulated mesh
19:52:04.002 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:52:05.658 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:52:06.748 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:52:07.444 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:52:37.817 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:52:44.142 : Error:checksum mismatch, Last Line:279
19:52:44.142 : Resend:280
19:56:22.028 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
19:59:58.413 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:00:00.154 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:00:01.691 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:00:02.822 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:01:01.102 : <Slic3r> => Generating perimeters
20:01:04.938 : <Slic3r> => Detecting solid surfaces
20:01:06.169 : <Slic3r> => Preparing infill surfaces
20:01:06.206 : <Slic3r> => Detect bridges
20:01:06.213 : <Slic3r> => Generating horizontal shells
20:01:06.252 : <Slic3r> => Combining infill
20:01:06.252 : <Slic3r> => Infilling layers
20:01:07.544 : <Slic3r> => Generating skirt
20:01:07.549 : <Slic3r> => Exporting G-code to C:\Users\Felix\AppData\Local\RepetierHost\composition.gcode
20:01:09.868 : <Slic3r> Done. Process took 13 minutes and 41.470 seconds
20:01:09.869 : <Slic3r> Filament required: 905.4mm (6.4cm3)
20:02:57.879 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:57.887 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:57.892 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:57.900 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:57.901 : Printing layer 1 of 30
20:02:57.911 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
<REDUDANT ERRORS SNIPPED OUT>
20:02:58.366 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:58.374 : Error:Line Number is not Last Line Number+1, Last Line:561
20:02:58.374 : Resend:562
20:02:58.382 : Error:Line Number is not Last Line Number+1, Last Line:561
20:02:58.382 : Resend:562
20:02:58.391 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:58.497 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:58.505 : Error:checksum mismatch, Last Line:573
20:02:58.505 : Resend:574
20:02:58.513 : Error:Line Number is not Last Line Number+1, Last Line:573
20:02:58.513 : Resend:574
20:02:58.522 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:58.629 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:58.636 : Error:checksum mismatch, Last Line:585
20:02:58.636 : Resend:586
20:02:58.645 : Error:Line Number is not Last Line Number+1, Last Line:585
20:02:58.645 : Resend:586
20:02:58.654 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:58.890 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:02:58.898 : Error:checksum mismatch, Last Line:611
20:02:58.898 : Resend:612
20:02:58.907 : Error:Line Number is not Last Line Number+1, Last Line:611
20:02:58.907 : Resend:612
20:02:58.916 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:00.202 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:00.209 : Error:checksum mismatch, Last Line:746
20:03:00.209 : Resend:747
20:03:00.217 : Error:Line Number is not Last Line Number+1, Last Line:746
20:03:00.217 : Resend:747
20:03:00.227 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:00.333 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:00.340 : Error:checksum mismatch, Last Line:758
20:03:00.340 : Resend:759
20:03:00.349 : Error:Line Number is not Last Line Number+1, Last Line:758
20:03:00.349 : Resend:759
20:03:00.358 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:00.594 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:00.602 : Error:checksum mismatch, Last Line:783
20:03:00.602 : Resend:784
20:03:00.611 : Error:Line Number is not Last Line Number+1, Last Line:783
20:03:00.611 : Resend:784
20:03:00.620 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:01.381 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:01.389 : Error:checksum mismatch, Last Line:862
20:03:01.389 : Resend:863
20:03:01.397 : Error:Line Number is not Last Line Number+1, Last Line:862
20:03:01.397 : Resend:863
20:03:01.407 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:01.643 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:01.651 : Error:checksum mismatch, Last Line:887
20:03:01.651 : Resend:888
20:03:01.659 : Error:Line Number is not Last Line Number+1, Last Line:887
20:03:01.659 : Resend:888
20:03:01.668 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:01.774 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:01.783 : Error:Line Number is not Last Line Number+1, Last Line:899
20:03:01.783 : Resend:900
20:03:01.787 : Error:Line Number is not Last Line Number+1, Last Line:899
20:03:01.787 : Resend:900
20:03:01.791 : Error:Line Number is not Last Line Number+1, Last Line:899
20:03:01.791 : Resend:900
20:03:01.799 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:01.803 : Error:Line Number is not Last Line Number+1, Last Line:901
20:03:01.803 : Resend:902
20:03:01.815 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:02.036 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:02.044 : Error:No Checksum with line number, Last Line:926
20:03:02.044 : Resend:927
20:03:02.053 : Error:Line Number is not Last Line Number+1, Last Line:926
20:03:02.053 : Resend:927
20:03:02.062 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:02.297 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:02.305 : Error:checksum mismatch, Last Line:951
20:03:02.306 : Resend:952
20:03:02.315 : Error:Line Number is not Last Line Number+1, Last Line:951
20:03:02.315 : Resend:952
20:03:02.326 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:02.560 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:02.569 : Error:checksum mismatch, Last Line:976
20:03:02.569 : Resend:977
20:03:02.576 : Error:Line Number is not Last Line Number+1, Last Line:976
20:03:02.576 : Resend:977
20:03:02.584 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:02.822 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:02.830 : Error:checksum mismatch, Last Line:1003
20:03:02.830 : Resend:1004
20:03:02.838 : Error:Line Number is not Last Line Number+1, Last Line:1003
20:03:02.838 : Resend:1004
20:03:02.847 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:03.346 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:03.354 : Error:checksum mismatch, Last Line:1055
20:03:03.354 : Resend:1056
20:03:03.362 : Error:Line Number is not Last Line Number+1, Last Line:1055
20:03:03.362 : Resend:1056
20:03:03.371 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:04.002 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:04.010 : Error:checksum mismatch, Last Line:1121
20:03:04.010 : Resend:1122
20:03:04.018 : Error:Line Number is not Last Line Number+1, Last Line:1121
20:03:04.018 : Resend:1122
20:03:04.027 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:04.526 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:04.534 : Error:checksum mismatch, Last Line:1173
20:03:04.534 : Resend:1174
20:03:04.542 : Error:Line Number is not Last Line Number+1, Last Line:1173
20:03:04.542 : Resend:1174
20:03:04.551 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:04.919 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:04.927 : Error:checksum mismatch, Last Line:1213
20:03:04.927 : Resend:1214
20:03:04.935 : Error:Line Number is not Last Line Number+1, Last Line:1213
20:03:04.935 : Resend:1214
20:03:04.944 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:05.051 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:05.058 : Error:Line Number is not Last Line Number+1, Last Line:1225
20:03:05.058 : Resend:1226
20:03:05.066 : Error:Line Number is not Last Line Number+1, Last Line:1225
20:03:05.066 : Resend:1226
20:03:05.075 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:05.182 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:05.189 : Error:Line Number is not Last Line Number+1, Last Line:1237
20:03:05.189 : Resend:1238
20:03:05.197 : Error:Line Number is not Last Line Number+1, Last Line:1237
20:03:05.197 : Resend:1238
20:03:05.206 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:05.312 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:05.320 : Error:checksum mismatch, Last Line:1249
20:03:05.320 : Resend:1250
20:03:05.329 : Error:Line Number is not Last Line Number+1, Last Line:1249
20:03:05.329 : Resend:1250
20:03:05.338 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:05.706 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:05.714 : Error:checksum mismatch, Last Line:1288
20:03:05.714 : Resend:1289
20:03:05.722 : Error:Line Number is not Last Line Number+1, Last Line:1288
20:03:05.722 : Resend:1289
20:03:05.731 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.230 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.238 : Error:checksum mismatch, Last Line:1340
20:03:06.238 : Resend:1341
20:03:06.246 : Error:Line Number is not Last Line Number+1, Last Line:1340
20:03:06.246 : Resend:1341
20:03:06.254 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.361 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.369 : Error:checksum mismatch, Last Line:1352
20:03:06.369 : Resend:1353
20:03:06.377 : Error:Line Number is not Last Line Number+1, Last Line:1352
20:03:06.377 : Resend:1353
20:03:06.386 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.492 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.500 : Error:checksum mismatch, Last Line:1364
20:03:06.500 : Resend:1365
20:03:06.508 : Error:Line Number is not Last Line Number+1, Last Line:1364
20:03:06.508 : Resend:1365
20:03:06.517 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.624 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.631 : Error:Line Number is not Last Line Number+1, Last Line:1376
20:03:06.631 : Resend:1377
20:03:06.639 : Error:Line Number is not Last Line Number+1, Last Line:1376
20:03:06.639 : Resend:1377
20:03:06.648 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.885 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:06.893 : Error:checksum mismatch, Last Line:1403
20:03:06.893 : Resend:1404
20:03:06.901 : Error:Line Number is not Last Line Number+1, Last Line:1403
20:03:06.901 : Resend:1404
20:03:06.910 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:07.016 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:07.024 : Error:No Checksum with line number, Last Line:1415
20:03:07.024 : Resend:1416
20:03:07.033 : Error:Line Number is not Last Line Number+1, Last Line:1415
20:03:07.033 : Resend:1416
20:03:07.042 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:08.458 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:08.466 : Error:checksum mismatch, Last Line:1564
20:03:08.466 : Resend:1565
20:03:08.474 : Error:Line Number is not Last Line Number+1, Last Line:1564
20:03:08.474 : Resend:1565
20:03:08.483 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:08.589 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:08.597 : Error:No Checksum with line number, Last Line:1576
20:03:08.597 : Resend:1577
20:03:08.605 : Error:Line Number is not Last Line Number+1, Last Line:1576
20:03:08.605 : Resend:1577
20:03:08.614 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:08.721 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:08.728 : Error:checksum mismatch, Last Line:1588
20:03:08.728 : Resend:1589
20:03:08.737 : Error:Line Number is not Last Line Number+1, Last Line:1588
20:03:08.737 : Resend:1589
20:03:08.746 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
<REDUNDANT ERRORS SNIPPED OUT>
20:03:08.983 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:08.990 : Error:checksum mismatch, Last Line:1613
20:03:08.990 : Resend:1614
20:03:08.999 : Error:Line Number is not Last Line Number+1, Last Line:1613
20:03:08.999 : Resend:1614
20:03:09.008 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.031 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.039 : Error:checksum mismatch, Last Line:1719
20:03:10.039 : Resend:1720
20:03:10.047 : Error:Line Number is not Last Line Number+1, Last Line:1719
20:03:10.047 : Resend:1720
20:03:10.056 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.163 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.170 : Error:Line Number is not Last Line Number+1, Last Line:1731
20:03:10.170 : Resend:1732
20:03:10.178 : Error:Line Number is not Last Line Number+1, Last Line:1731
20:03:10.178 : Resend:1732
20:03:10.187 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.293 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.301 : Error:checksum mismatch, Last Line:1743
20:03:10.301 : Resend:1744
20:03:10.309 : Error:Line Number is not Last Line Number+1, Last Line:1743
20:03:10.309 : Resend:1744
20:03:10.318 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)<REDUDANT ERRORS SNIPPED OUT>
20:03:10.425 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.433 : Error:checksum mismatch, Last Line:1755
20:03:10.433 : Resend:1756
20:03:10.442 : Error:Line Number is not Last Line Number+1, Last Line:1755
20:03:10.442 : Resend:1756
20:03:10.451 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.687 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.695 : Error:checksum mismatch, Last Line:1780
20:03:10.695 : Resend:1781
20:03:10.704 : Error:Line Number is not Last Line Number+1, Last Line:1780
20:03:10.704 : Resend:1781
20:03:10.713 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.958 : Printer stopped deu to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
20:03:10.962 : Error:Line Number is not Last Line Number+1, Last Line:1806
20:03:10.962 : Resend:1807
20:03:10.970 : Error:Line Number is not Last Line Number+1, Last Line:1806
20:03:10.970 : Resend:1807
20:03:10.978 : Error:Line Number is not Last Line Number+1, Last Line:1806
20:03:10.978 : Resend:1807
20:03:10.986 : Error:Line Number is not Last Line Number+1, Last Line:1806
20:03:10.986 : Resend:1807
20:03:10.995 : Error:Line Number is not Last Line Number+1, Last Line:1806
20:03:10.995 : Resend:1807
20:03:11.003 : Error:Line Number is not Last Line Number+1, Last Line:1806
20:03:11.003 : Resend:1807
20:03:11.011 : Error:Line Number is not Last Line Number+1, Last Line:1806
20:03:11.011 : Resend:1807
20:03:11.011 : Receiving only error messages. Stopped communication.
Any and all help would be much much appreciated. I'm really looking forward to printing something with this guy.
gabrielk
Re: No control over printer?
Post by gabrielk »
I think i have this kind of problem when i disconnected my nozzle and its thermistor.
Felix
Post by Felix »
Hmmm, just on a whim, i decided to check something out. I plugged in the thermistor to the heating bed into the hotend instead. Seems to have fixed my problems... Kinda weird though. How do the other heads (like the pen or the guage) work without a thermistor plugged up. Or is that one of those "oh by the way" things?
johnoly99
Post by johnoly99 »
Felix, john here. The firmware comes by default set to kill the printer if there is no thermistor attached. It's a safety, so that if it were to come unplugged during a print, it wouldn't let it burn up the hotend. There are two ways to bypass it. one, just leave it plugged in. Two, go into the firmware, in configuration.h and change temp_sens_0 to 0 and it will ignore that thermistor.
Johnoly
