New member from Saratoga NY
Whats up! I jot it all assembled and then popped a fuse lol go me! should have PAYED ATTENTION TO WHICH WIRE WENT WHERE FOR PEEK FAN.
Re: New member from Saratoga NY
Welcome. The build is a very fun process in my opinion. If i could easily obtain another one i would purchase it, build it and sell my current one just to go through the build process again.
Search the forum for fuses, if you are in a hurry you can solder a blade type fuse to your burned fuse to keep going untill you get your replacement.
The build was fun, I had a fever the whole time, that wasnt! I was building it on days that I took off because I was sick. On the first day off, I realized that the printer I ordered two weeks prior, HAD ARRIVED. Threw it together in ~16hrs. Printed with some transparent black ABS to do the calibration cube and the PEEK Fan shroud. The calibration took me 20 min.
Although I'm used to calibrating the davinci, maybe that helped. haha
