My friend and I Purchased a Rostock Max V2 kit in august of least year. We had the printer working and were almost through with calibrating it. This error message only ever happened after we downloaded the new version of Ardunio and the latest version of the V2 script.
What does this error mean? Is this a problem with the board or the computer's memory?
What does "Low memory available" mean?
Re: What does "Low memory available" mean?
If this is showing up at the log window in the Arduino SDK when you are compiling the firmware, you can ignore it. It's just a warning message for programmers telling you that your code is using up nearly all the memory.
Agreed. This is a feature of the 1.6.0 Arduino IDE that was released a short time ago.
