G/M code to delete file from sd card
teoman
Post by teoman »
Does anyone know if M30 works on our printers?
M30 is used to delete files from the SD card. I am having problems with my memory if an object has 3 different parts. So i was thinking of generating all of the gcode files and adding M30 to delete that file at the end. So once i print it, it conveniently removes itself from the sd card.
Ref: http://reprap.org/wiki/G-code
Return to “The Lounge”
