Z-Unlimited add-on for Ultimaker
KAS
Post by KAS »
Okay, SEMI-practical depending on your needs---and freaking cool.
https://www.kickstarter.com/projects/16 ... f=category
[youtube]http://www.youtube.com/watch?v=nzwaVQaQgmI[/youtube]
Re: Z-Unlimited add-on for Ultimaker
Brian (TrickLaser) and I were scheming about a Rostock with no base that could just print on a glass table or something like that. That idea could be adapted into something kind of like this.
Nylocke
Post by Nylocke »
Not practical? I see it working right now for a real application? Seems practical to me?
KAS
Post by KAS »
Nylocke wrote:Not practical? I see it working right now for a real application? Seems practical to me?
okay, My apologies. Didn't mean to offend you or anyone else with a need to prototype giant prints.
Nylocke
Post by Nylocke »
You didn't offend me, I just failed to see how a larger build height being demonstrated wasn't practical.
I thought the support features were cool. As the height of your prints increase the lever forces can topple your print, so he added arms you can wind thin strings onto and thread them through the print as its going. The threads are thin enough you can just pull them out when done. Pretty smart.
TFMike
Post by TFMike »
I had thought about adding longer / larger almunimum or steel extrusions to the rostock max to achieve something like this, it would require someone with some time to re design all of the MDF melamine housing though.
KAS
Post by KAS »
TFMike wrote:I had thought about adding longer / larger almunimum or steel extrusions to the rostock max to achieve something like this, it would require someone with some time to re design all of the MDF melamine housing though.
Apparently it's somewhat easy, just need Longer extrusions, belts and wires. Granted it's not that tall.
http://forum.seemecnc.com/viewtopic.php ... ion#p64123
BenTheRighteous
Post by BenTheRighteous »
Did a part fall over at 1:28? Hard to tell if that was a failure; anyway, it doesn't seem to have set them back much even if it was.
redoverred
Post by redoverred »
The z-height of a delta printer is independent from the x-y positioning, so if you had extrusions JUST long enough to position all around the build surface and had a separate z-axis that raised or lowered the whole contraption you'd be all set.
TFMike
Post by TFMike »
I meant using larger extrusions, like 40 mm instead of 25.4 or whatever they use stock, and using steel instead of aluminum.
KAS
Post by KAS »
gotcha, in that case I wouldn't use melamine and just design something all metal.
TFMike
Post by TFMike »
KAS wrote:gotcha, in that case I wouldn't use melamine and just design something all metal.
Had thought about that too, something rugged like the printrbot simple metal would be awesome, but costly. I think redroverred's idea would be the most practical. I wonder how hard it would be to retrofit a custom rostock with stubby legs onto one of these dutch z unlimited contraptions.
Nylocke
Post by Nylocke »
That'd be interesting from a calibration standpoint.
redoverred
Nylocke wrote:That'd be interesting from a calibration standpoint.
Not so much. Set the z-axis (mechanism to move the whole frame up and down) to zero and then use regular delta calibration on the short delta tower (the frame section) to calibrate. You simply have to program the delta kinematics to only move the nozzle at the z-zero height for the delta section and the z-level kinematics go straight to the special z-axis. It would be pretty much as "simple" as it is now, but the hard part is to remove all flexibility from the frame and z-axis sections so when you raise the delta portion of the printer it moves the whole thing the same amount without a lot of flex.
Return to “The Lounge”
