Thanks to Geneb manual and videos on YT and all you guys here it was fairly simply task for me although it is my first 3d printer.
Here is my machine I will name it stage 1: here you can see the my very first prints I use setting from manual: after printing a lot of calibration cubes and stuff i want to do something else, owl an bear. ( not calibrated extruder at all) when I was bored of black color I changed filament to green, and all things goes a lot smoother (big difference i nozzle temp between them too I think at the same time i changed firmware to repetier): After that I try to calibrate extruder to get better infill (change e steps from 292 to 305), and I spotted problems with detached infill, so after Mhackney's tips i redo the u-joints. i take piece of metal 8mm thick ( the same as u jonts) and try to slide it in the arms. They are right now very smooth.
At that time I also make some mods which i describe in mods/iupgrades subforum.
1. extruder - smoother moves, no rubbing,
http://forum.seemecnc.com/viewtopic.php?f=35&t=1168
2.end stops - more consistent Z, more accurate tuning
http://forum.seemecnc.com/viewtopic.php?f=35&t=1170
3.belt tensioner - more control over tension, centering belt, smoother moves.
http://forum.seemecnc.com/viewtopic.php?f=35&t=1169
Lately i have some problems with nozzle so i dismantled it (I didn't check it since first assembly) and i find out something like this: Tight now i have next to me 1m of 2x4 ptfe tubing and 1m of 4x6 ptfe tubing so I will replace them.
and now questions:
1. Is that normal that wider tube is cutted alk the way?
2.I have old nozzle, so what dimensions should have both tubes (length) and how shoul i cut them, maybe use pencil sharpener to make bevel on the end for better fit?
Please help, and sorry for my english
