All of the sudden my bed is taking a long time to heat up. The light flickers now instead of showing as solid when it's heating. I have a feeling it's the power supply going bad, but I'm not sure how to confirm this. It's been acting weird lately. Like causing a delay to turn off or on when i use the direct switch in the back. Also i'm not sure if i just never noticed this but when i move my skates and the power is off it causes my LCD to come on. Is this just residual power I'm creating with my motors to power on the board? Anyways i've been sitting here for 30min and it's only upto 43.4c. My E3D v6 has no problem getting upto 220 as usual. I checked all my wires and everything seems fine. Reading other posts it was suggested to check the power on the onyx at the solder points and the input and output power on the RAMBO on and off. How do i tell if it's the power supply or something else?
Also, i just spent two days setting up the air struder and as soon as i'm ready to test it, this happens. Why do our printers love to abuse us so much? I feel like this always happens. So frustrating
Solution: Somehow how heated bad MAX PID got changed to 40 which limited the power going out. Once i set it back to 255 everything was back to normal. I would be cautious when editing your EEPROM settings with mattercontrol.
