Fiberoptic splitter/couplers
I have been experimenting with making low cost fiber optic splitter/coupler for underwater ROV/AUV project. Some researchers had made coupler/splitter with acrylic and a cnc mini mill. So tried it with an Orion instead, it works, though I'd like to improve signal loss performance https://www.dropbox.com/s/rkc4o3xr8x0qb ... o.jpg?dl=0. Trying to use a single low cost consumer TOSlink fiber cable, 30ft to 100ft for simultaneous data uplink/downlink on ROV. The print was very accurate in leaving a small void at the fiber intersection which is then filled with a clear epoxy, though i need to get the proper UV cure glue since when I mix the two part epoxy it forms small bubbles which scatter the light. Any ideas or suggestion on improvements would be great!
Re: Fiberoptic splitter/couplers
Generally for that kind of stuff first you need to first vacuum your epoxy to get the bubbles out.
thanks, now i remember like when you do those self car window crack repair, they have you pull the syringe plunger back to remove the air!
Odd I feel like I just watch this...He does some weird things on his channel. Might not be optical quality enough for your application though.
[youtube]http://www.youtube.com/watch?v=avXgv4g2a8U[/youtube]
I have called these guys and their technical support is superb.
Let them know what your trying to do and they will have a product.
ASK for sample to test first.
http://www.masterbond.com/
