generator spool former
stonewater
Post by stonewater »
thought I would post this... this is for a non lenz generator, the wires will be wrapped around it and tig welding rod dropped into the center for a core.
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Tonkabot
Re: generator spool former
Post by Tonkabot »
I looked up 'non-lenz' to see what you were talking about. Found a website with lots of CAPITAL LETTERS and claimed that a non-lenz generator should be able to achieve over-unity.
Over-Unity is a buzzword for all the free-energy, laws of physics need not apply crowd.
So are you building this for fun, or do you believe you are going to get more energy out than you put in?
[Disclaimer: I am an over-unity denier - The laws of physics are fixed and cannot be broken - TANSTAAFL ]
gestalt73
Post by gestalt73 »
Your print looks good, I see the telltale signs of MatterControl's triangle infill, what top surface thickness are you using?
And I don't see any support marks, was it printed in multiple pieces?
If you can, post some pics of your non-lenz generator when it's assembled.
(I love these types of experiments. Not because I believe that they will uncover new physics, but they do excite the imagination, and provide an excuse to learn everything you can about the known laws of physics).
So while you're assembling your generator, learn as much as you can from the existing "fields" of study on the subject: motors, generators, electricity and magnetism, energy equations, etc). Have fun!
stonewater
Gestalt,
yep mattercontrol.... and yes it is in 2 pieces, the top glues on, much easier than supports, no wasted filament. the top is 100 mm thick the bottom 200 mm. 5 top and bottom layers. using the hex infill now that prototype was pla I am using abs now for strength and abs glue is cheap from the hardware store.
walter russell, and steinmetz, Tesla, John Bedini, Thomas Bearden, and Eric Dollard whom I have met a few times might disagree with the standard physics models. quantum entanglement has quite a few people scratching their heads also....
http://www.thesurfaceofthesun.com for an alternate view to the gas model of the sun, and an interesting movie is called the thunderbolts of the gods, you can watch it on youtube. also the electric universe, a lot of what these guys have postulated has been confirmed by NASA
Tonkabot,
lenzess simply means non reflective on the prime mover. if I take a big coil of wire and push it up close to a rotor with magnets spinning and do it just to the point where it creates drag, then back it off, then the load is non reflective. I still can harvest the field lines coming from the passing rotor magnets, and do something with it, charge a cap, use the cap to pulse charge a battery.. its just a novel way of getting more out of a bunch of spinning magnets.
I have some pretty amazing things on my bench and I can tell you I have seen c.o.p. of 9 to 1... meters on the machine. but even 9 to 1 is not enough to do anything with. a self runner is easy, my solar panels are self runners, it just harvests fuel from photons, which is free energy..... paid for itself years ago, it is truly c.o.p. of infinity . my heatpump has a cop of 4 to 1 by harvesting the differential from the environment.
the ballast in your fluorescent lights is tesla technology in plain sight. what if I could separate hydrogen from water not using brute force , like stan Meyers did using resonance....
ahh said to much already. anyway thanks guys for looking at it, my printer has opened up a whole world of experimentation that otherwise would cost me a tirp to the machine shop.
http://www.teslagenx.com is my hobby business... by day I fix things....
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
I dug into the Stan Meyers thing for a while, put a couple electrolyzers on my car, etc... I was surprised how many intelligent people didn't understand the concept and were quick to dismiss it, claim that it was an over-unity device, and call me crazy... Nonsense, it's a combustion engine that uses something other that gasoline for fuel. You put water in instead of gas, and it gets burned... Pretty simple. Nobody's claiming that you get free energy, but that's always the conclusion that people jumped to. It was kind of annoying.
Stan's molecular resonance method is a bit mysterious though... I hope somebody cracks that one open soon, because I believe in it.
stonewater
J,
yea stan was the real deal, a lot of inventors are, a lot are crackpots too like that Timothy Thrapp guy. too many lost inventions to even begin talking about them.
I meant to ask you about your DC to DC converter, what brand and model did you end up getting?
Tom C
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
stonewater wrote:I meant to ask you about your DC to DC converter, what brand and model did you end up getting?
http://www.amazon.com/gp/product/B00BWK ... UTF8&psc=1
