RAMBO 4th thermistor
Generic Default
Post by Generic Default »
Hi everyone,
I've been helping my friend build a printer. At this point it prints decently, but it needs a heated bed to work with ABS and nylon. It has a 20v power supply so the bed heats up quickly; the problem is that I can't get a thermistor reading for it. On the Rambo board there are four thermistor inputs. Thermistor input 0 is working fine with the hotend. Thermistor inputs 1 and 2 are fried from being shorted a year or so ago. They are gone.
Thermistor input 3 needs to work with the heated bed, but I can't get it to read the thermistor 3 input because it some weird analog thing. Check out the rambo pins page to see what I mean.
http://reprap.org/wiki/Rambo_development
What number or phrase do I need to specify in the pins.h file to read the thermistor input 3 correctly?
EDIT:
When I try to read from pin 7, the heated bed doesn't even show up in repetier host. Pins 0,1, and 2 all make the bed show up. Pins 1 and 2 read around 120 degrees at room temperature, so they are broken. Pin 0 reads the exact hotend temperature.
Check out the Tri hotend!
Holy1
Re: RAMBO 4th thermistor
Post by Holy1 »
Silly question but you have turned on the heated bed in the configuration.h file?
Generic Default
Yep, it's on and I've been able to heat up the bed. When I tell it to read from Thermistor inputs 0, 1, or 2, the heated bed shows up in repetier host and I can turn it on or off.
When I tell it to read from thermistor input 3, the heated bed doesn't show up in repetier host and I can't control it.
Earthbound
Post by Earthbound »
around line 189 of Configuration.h:
#define EXT0_TEMPSENSOR_PIN 7
should give you a reading for EXT0 if thermistor when thermistor is connected at T3.
Generic Default
I tried that, and it showed a temperature of -20 degrees that was not changing. I think something is wrong with the pin assignments; pin 7 says it should read from the thermistor 3 input but at the same time it is pin 7 that is used to output power to the heated bed. Has anyone used the 4th thermistor input before?
EDIT:
To clarify, the repetier firmware uses pin numbers to decide which pin to read from. Digital pin 7 is assigned to Heat 1, but Analog pin is assigned to pin 7 also.
Last edited by Generic Default on Sat Apr 25, 2015 6:40 pm, edited 1 time in total.
Earthbound
Generic Default wrote:I tried that, and it showed a temperature of -20 degrees that was not changing. I think something is wrong with the pin assignments; pin 7 says it should read from the thermistor 3 input but at the same time it is pin 7 that is used to output power to the heated bed. Has anyone used the 4th thermistor input before?
Pin assignments are OK. Analog Pin 7 is physical pin 90 and is wired to the T3 connector. Digital Pin 7 is physical pin 16, which controls the Heat1 output. Yes, they are both defined as 7, but the pieces of code are targeted at different types of pins.
Generic Default
Why does it not work then? When I try to read from pin 7, the temperature shows as -20 degrees. How can I read from that thermistor input to control the bed temperature?
Earthbound
Post or send me your Configuration.h file.
Generic Default
    This file is part of Repetier-Firmware.
    Repetier-Firmware is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    Repetier-Firmware is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
/**************** READ FIRST ************************
   This configuration file was created with the configuration tool. For that
   reason, it does not contain the same informations as the original Configuration.h file.
   It misses the comments and unused parts. Open this file file in the config tool
   to see and change the data. You can also upload it to newer/older versions. The system
   will silently add new options, so compilation continues to work.
   This file is optimized for version 0.92
   generator: http://www.repetier.com/firmware/v092/
   If you are in doubt which named functions use which pins on your board, please check the
   pins.h for the used name->pin assignments and your board documentation to verify it is
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 301
#include "pins.h"
// ################## EDIT THESE SETTINGS MANUALLY ################
//  Microstepping mod eof your RAMO board
#define MICROSTEP_MODES { 8,8,8,8,8 } // [1,2,4,8,16]
// Motor Current setting (Only functional when motor driver current ref pins are connected to a digital trimpot on supported boards)
    #define MOTOR_CURRENT { 120,120,120,120,120 } // Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A)
// ################ END MANUAL SETTINGS ##########################
#define FAN_BOARD_PIN -1
//#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
// Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
// If it is incompatible you will get compiler errors about write functions not beeing compatible!
//#define COMPAT_PRE1
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 80
#define EXTRUDER_FAN_COOL_TEMP 20
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 20
#define DECOUPLING_TEST_MIN_TEMP_RISE 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_START_COMMANDS ""
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_STEPS_PER_MM 92
#define EXT0_TEMPSENSOR_TYPE 8
#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT0_HEATER_PIN HEATER_0_PIN
#define EXT0_STEP_PIN ORIG_E0_STEP_PIN
#define EXT0_DIR_PIN ORIG_E0_DIR_PIN
#define EXT0_INVERSE 0
#define EXT0_ENABLE_PIN E0_ENABLE_PIN
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 950
#define EXT0_MAX_START_FEEDRATE 10
#define EXT0_MAX_ACCELERATION 2000
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 5
#define EXT0_PID_INTEGRAL_DRIVE_MAX 30
#define EXT0_PID_INTEGRAL_DRIVE_MIN 5
#define EXT0_PID_PGAIN_OR_DEAD_TIME 5
#define EXT0_PID_I 10
#define EXT0_PID_D 30
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_ADVANCE_BACKLASH_STEPS 0
#define EXT0_WAIT_RETRACT_TEMP 15
#define EXT0_WAIT_RETRACT_UNITS 0
#define EXT0_SELECT_COMMANDS ""
#define EXT0_DESELECT_COMMANDS ""
#define EXT0_EXTRUDER_COOLER_PIN -1
#define EXT0_EXTRUDER_COOLER_SPEED 64
#define EXT0_DECOUPLE_TEST_PERIOD 12000
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_LONG_LENGTH 13
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_EXTRA_LENGTH 0
#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 0
#define RETRACTION_UNDO_SPEED 20
#define FILAMENTCHANGE_X_POS 0
#define FILAMENTCHANGE_Y_POS 0
#define FILAMENTCHANGE_Z_ADD  2
#define FILAMENTCHANGE_REHOME 1
#define FILAMENTCHANGE_SHORTRETRACT 5
#define FILAMENTCHANGE_LONGRETRACT 50
#define RETRACT_DURING_HEATUP true
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 900
#define NUM_TEMPS_USERTHERMISTOR0 0
#define USER_THERMISTORTABLE0 {}
#define NUM_TEMPS_USERTHERMISTOR1 0
#define USER_THERMISTORTABLE1 {}
#define NUM_TEMPS_USERTHERMISTOR2 0
#define USER_THERMISTORTABLE2 {}
#define GENERIC_THERM_VREF 5
#define GENERIC_THERM_NUM_ENTRIES 33
#define HEATER_PWM_SPEED 0
// ############# Heated bed configuration ########################
#define HAVE_HEATED_BED 1
#define HEATED_BED_MAX_TEMP 120
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_SENSOR_TYPE 1
#define HEATED_BED_SENSOR_PIN TEMP_0_PIN
#define HEATED_BED_HEATER_PIN HEATER_1_PIN
#define HEATED_BED_SET_INTERVAL 5000
#define HEATED_BED_HEAT_MANAGER 0
#define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255
#define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define HEATED_BED_PID_DGAIN 290
#define HEATED_BED_PID_MAX 255
#define HEATED_BED_DECOUPLE_TEST_PERIOD 300000
#define MIN_EXTRUDER_TEMP 0
#define MAXTEMP 340
#define MIN_DEFECT_TEMPERATURE -10
#define MAX_DEFECT_TEMPERATURE 340
// ################ Endstop configuration #####################
#define ENDSTOP_PULLUP_X_MIN true
#define ENDSTOP_X_MIN_INVERTING true
#define MIN_HARDWARE_ENDSTOP_X true
#define ENDSTOP_PULLUP_Y_MIN true
#define ENDSTOP_Y_MIN_INVERTING true
#define MIN_HARDWARE_ENDSTOP_Y true
#define ENDSTOP_PULLUP_Z_MIN true
#define ENDSTOP_Z_MIN_INVERTING true
#define MIN_HARDWARE_ENDSTOP_Z true
#define ENDSTOP_PULLUP_X_MAX true
#define ENDSTOP_X_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_X true
#define ENDSTOP_PULLUP_Y_MAX true
#define ENDSTOP_Y_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_Y true
#define ENDSTOP_PULLUP_Z_MAX true
#define ENDSTOP_Z_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_Z true
#define max_software_endstop_r true
#define min_software_endstop_x false
#define min_software_endstop_y false
#define min_software_endstop_z false
#define max_software_endstop_x true
#define max_software_endstop_y true
#define max_software_endstop_z true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_X_BACK_ON_HOME 5
#define ENDSTOP_Y_BACK_ON_HOME 5
#define ENDSTOP_Z_BACK_ON_HOME 5
#define ALWAYS_CHECK_ENDSTOPS 1
// ################# XYZ movements ###################
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 340
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_CORRECTION 0
#define DISTORTION_CORRECTION_POINTS 5
#define DISTORTION_CORRECTION_R 100
#define DISTORTION_PERMANENT 1
#define DISTORTION_UPDATE_FREQUENCY 15
#define DISTORTION_START_DEGRADE 0.5
#define DISTORTION_END_HEIGHT 1
#define DISTORTION_EXTRAPOLATE_CORNERS 0
// ##                           Movement settings                                          ##
#define FEATURE_BABYSTEPPING 1
#define BABYSTEP_MULTIPLICATOR 1
#define DELTA_SEGMENTS_PER_SECOND_PRINT 180 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other moves
// Delta settings
#define DELTA_DIAGONAL_ROD 445 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_RADIUS_CORRECTION_A 0
#define DELTA_RADIUS_CORRECTION_B 0
#define DELTA_RADIUS_CORRECTION_C 0
#define DELTA_DIAGONAL_CORRECTION_A 0
#define DELTA_DIAGONAL_CORRECTION_B 0
#define DELTA_DIAGONAL_CORRECTION_C 0
#define END_EFFECTOR_HORIZONTAL_OFFSET 0
#define CARRIAGE_HORIZONTAL_OFFSET 0
#define DELTA_MAX_RADIUS 150
#define ROD_RADIUS 209.25
#define PRINTER_RADIUS 209.25
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_X_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Y_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Z_ENDSTOP_OFFSET_STEPS 0
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
//#define SOFTWARE_LEVELING
#define DELTASEGMENTS_PER_PRINTLINE 24
#define STEPPER_INACTIVE_TIME 360L
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define HOMING_ORDER HOME_ORDER_ZXY
#define ENABLE_BACKLASH_COMPENSATION 0
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define STEP_DOUBLER_FREQUENCY 12000
#define ALLOW_QUADSTEPPING 1
#define DOUBLE_STEP_DELAY 1 // time in microseconds
#define MAX_HALFSTEP_INTERVAL 1999
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define PRINTLINE_CACHE_SIZE 16
#define MOVE_CACHE_LOW 10
#define LOW_TICKS_PER_MOVE 250000
#define FEATURE_TWO_XSTEPPER 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define X2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_TWO_YSTEPPER 0
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_TWO_ZSTEPPER 0
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_DITTO_PRINTING 0
#define USE_ADVANCE 0
#define ENABLE_QUADRATIC_ADVANCE 0
// ################# Misc. settings ##################
#define BAUDRATE 250000
#define ENABLE_POWER_ON_STARTUP 1
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define WAITING_IDENTIFIER "wait"
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#define PS_ON_PIN ORIG_PS_ON_PIN
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
Servos are controlled by a pulse width normally between 500 and 2500 with 1500ms in center position. 0 turns servo off.
WARNING: Servos can draw a considerable amount of current. Make sure your system can handle this or you may risk your hardware!
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS  -1
#define SERVO1_NEUTRAL_POS  -1
#define SERVO2_NEUTRAL_POS  -1
#define SERVO3_NEUTRAL_POS  -1
#define UI_SERVO_CONTROL 0
#define FAN_KICKSTART_TIME  200
        #define FEATURE_WATCHDOG 0
// #################### Z-Probing #####################
#define FEATURE_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 10
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_WAIT_BEFORE_TEST 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 1
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define Z_PROBE_START_SCRIPT ""
#define Z_PROBE_FINISHED_SCRIPT ""
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
#define SDSUPPORT 0
#define SDCARDDETECT -1
#define SDCARDDETECTINVERTED 0
#endif
#define SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! */
#define SD_RUN_ON_STOP ""
#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 1
#define ARC_SUPPORT 1
#define FEATURE_MEMORY_POSITION 1
#define FEATURE_CHECKSUM_FORCED 0
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 0
#define UI_LANGUAGE 0
#define UI_PRINTER_NAME "RepRap"
#define UI_PRINTER_COMPANY "Home made"
#define UI_PAGES_DURATION 4000
#define UI_ANIMATION 1
#define UI_SPEEDDEPENDENT_POSITIONING 0
#define UI_DISABLE_AUTO_PAGESWITCH 1
#define UI_AUTORETURN_TO_MENU_AFTER 30000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_FIRST_REPEAT 500
#define UI_KEY_REDUCE_REPEAT 50
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define CASE_LIGHT_DEFAULT_ON 1
#define UI_START_SCREEN_DELAY 1000
#define UI_DYNAMIC_ENCODER_SPEED 1
Beeper sound definitions for short beeps during key actions
and longer beeps for important actions.
Parameter is delay in microseconds and the secons is the number of repetitions.
Values must be in range 1..255
#define BEEPER_SHORT_SEQUENCE 2,2
#define BEEPER_LONG_SEQUENCE 8,8
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 60
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 110
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
#define UI_SET_MIN_HEATED_BED_TEMP  30
#define UI_SET_MAX_HEATED_BED_TEMP 120
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define UI_SET_EXTRUDER_FEEDRATE 2
#define UI_SET_EXTRUDER_RETRACT_DISTANCE 3
#endif
/* Below you will find the configuration string, that created this Configuration.h
========== Start configuration string ==========
    "editMode": 1,
    "processor": 0,
    "baudrate": 250000,
    "xStepsPerMM": 80,
    "yStepsPerMM": 80,
    "zStepsPerMM": 80,
    "xInvert": 0,
    "xInvertEnable": 0,
    "eepromMode": 1,
    "yInvert": 0,
    "yInvertEnable": 0,
    "zInvert": 0,
    "zInvertEnable": 0,
    "extruder": [
            "id": 0,
            "heatManager": 3,
            "pidDriveMin": 40,
            "pidDriveMax": 230,
            "pidMax": 255,
            "sensorType": 1,
            "sensorPin": "TEMP_0_PIN",
            "heaterPin": "HEATER_0_PIN",
            "maxFeedrate": 50,
            "startFeedrate": 20,
            "invert": "0",
            "invertEnable": "0",
            "acceleration": 5000,
            "watchPeriod": 1,
            "pidP": 7,
            "pidI": 2,
            "pidD": 40,
            "advanceK": 0,
            "advanceL": 0,
            "waitRetractTemp": 150,
            "waitRetractUnits": 0,
            "waitRetract": 0,
            "stepsPerMM": 370,
            "coolerPin": -1,
            "coolerSpeed": 255,
            "selectCommands": "",
            "deselectCommands": "",
            "xOffset": 0,
            "yOffset": 0,
            "xOffsetSteps": 0,
            "yOffsetSteps": 0,
            "stepper": {
                "name": "Extruder 0",
                "step": "ORIG_E0_STEP_PIN",
                "dir": "ORIG_E0_DIR_PIN",
                "enable": "E0_ENABLE_PIN"
            "advanceBacklashSteps": 0,
            "decoupleTestPeriod": 12
    "uiLanguage": 0,
    "uiController": 0,
    "xMinEndstop": 1,
    "yMinEndstop": 1,
    "zMinEndstop": 1,
    "xMaxEndstop": 0,
    "yMaxEndstop": 0,
    "zMaxEndstop": 0,
    "motherboard": 301,
    "driveSystem": 3,
    "xMaxSpeed": 200,
    "xHomingSpeed": 40,
    "xTravelAcceleration": 100,
    "xPrintAcceleration": 1000,
    "yMaxSpeed": 200,
    "yHomingSpeed": 40,
    "yTravelAcceleration": 100,
    "yPrintAcceleration": 1000,
    "zMaxSpeed": 2,
    "zHomingSpeed": 2,
    "zTravelAcceleration": 100,
    "zPrintAcceleration": 100,
    "xMotor": {
        "name": "X motor",
        "step": "ORIG_X_STEP_PIN",
        "dir": "ORIG_X_DIR_PIN",
        "enable": "ORIG_X_ENABLE_PIN"
    "yMotor": {
        "name": "Y motor",
        "step": "ORIG_Y_STEP_PIN",
        "dir": "ORIG_Y_DIR_PIN",
        "enable": "ORIG_Y_ENABLE_PIN"
    "zMotor": {
        "name": "Z motor",
        "step": "ORIG_Z_STEP_PIN",
        "dir": "ORIG_Z_DIR_PIN",
        "enable": "ORIG_Z_ENABLE_PIN"
    "enableBacklash": "0",
    "backlashX": 0,
    "backlashY": 0,
    "backlashZ": 0,
    "stepperInactiveTime": 360,
    "maxInactiveTime": 0,
    "xMinPos": 0,
    "yMinPos": 0,
    "zMinPos": 0,
    "xLength": 200,
    "yLength": 200,
    "zLength": 120,
    "alwaysCheckEndstops": "1",
    "disableX": "0",
    "disableY": "0",
    "disableZ": "0",
    "disableE": "0",
    "xHomeDir": "-1",
    "yHomeDir": "-1",
    "zHomeDir": 1,
    "xEndstopBack": 1,
    "yEndstopBack": 1,
    "zEndstopBack": 0,
    "deltaSegmentsPerSecondPrint": 180,
    "deltaSegmentsPerSecondTravel": 70,
    "deltaDiagonalRod": 445,
    "deltaHorizontalRadius": 209.25,
    "deltaAlphaA": 210,
    "deltaAlphaB": 330,
    "deltaAlphaC": 90,
    "deltaDiagonalCorrA": 0,
    "deltaDiagonalCorrB": 0,
    "deltaDiagonalCorrC": 0,
    "deltaMaxRadius": 150,
    "deltaFloorSafetyMarginMM": 15,
    "deltaRadiusCorrA": 0,
    "deltaRadiusCorrB": 0,
    "deltaRadiusCorrC": 0,
    "deltaXOffsetSteps": 0,
    "deltaYOffsetSteps": 0,
    "deltaZOffsetSteps": 0,
    "deltaSegmentsPerLine": 24,
    "stepperHighDelay": 0,
    "directionDelay": 0,
    "stepDoublerFrequency": 12000,
    "allowQuadstepping": "1",
    "doubleStepDelay": 1,
    "maxHalfstepInterval": 1999,
    "maxJerk": 20,
    "maxZJerk": 0.3,
    "moveCacheSize": 16,
    "moveCacheLow": 10,
    "lowTicksPerMove": 250000,
    "enablePowerOnStartup": "1",
    "echoOnExecute": "1",
    "sendWaits": "1",
    "ackWithLineNumber": "1",
    "killMethod": 1,
    "useAdvance": "0",
    "useQuadraticAdvance": "0",
    "powerInverting": 0,
    "mirrorX": 0,
    "mirrorXMotor": {
        "name": "Extruder 1",
        "step": "ORIG_E1_STEP_PIN",
        "dir": "ORIG_E1_DIR_PIN",
        "enable": "E1_ENABLE_PIN"
    "mirrorY": 0,
    "mirrorYMotor": {
    "mirrorZ": 0,
    "mirrorZMotor": {
    "dittoPrinting": "0",
    "featureServos": "0",
    "servo0Pin": 11,
    "servo1Pin": -1,
    "servo2Pin": -1,
    "servo3Pin": -1,
    "featureWatchdog": "0",
    "hasHeatedBed": "0",
    "enableZProbing": "0",
    "extrudeMaxLength": 160,
    "homeOrder": "HOME_ORDER_ZXY",
    "featureController": 0,
    "uiPrinterName": "RepRap",
    "uiPrinterCompany": "Home made",
    "uiPagesDuration": 4000,
    "uiAnimation": "1",
    "uiDisablePageswitch": "1",
    "uiAutoReturnAfter": 30000,
    "featureKeys": "0",
    "uiEncoderSpeed": 1,
    "uiKeyBouncetime": 10,
    "uiKeyFirstRepeat": 500,
    "uiKeyReduceRepeat": 50,
    "uiKeyMinRepeat": 50,
    "featureBeeper": "0",
    "uiPresetBedTempPLA": 60,
    "uiPresetBedABS": 110,
    "uiPresetExtruderPLA": 190,
    "uiPresetExtruderABS": 240,
    "uiMinHeatedBed": 30,
    "uiMaxHeatedBed": 120,
    "uiMinEtxruderTemp": 170,
    "uiMaxExtruderTemp": 260,
    "uiExtruderFeedrate": 2,
    "uiExtruderRetractDistance": 3,
    "uiSpeeddependentPositioning": "0",
    "maxBedTemperature": 120,
    "bedSensorType": 1,
    "bedSensorPin": "TEMP_1_PIN",
    "bedHeaterPin": "HEATER_1_PIN",
    "bedHeatManager": 0,
    "bedUpdateInterval": 5000,
    "bedPidDriveMin": 80,
    "bedPidDriveMax": 255,
    "bedPidP": 196,
    "bedPidI": 33,
    "bedPidD": 290,
    "bedPidMax": 255,
    "bedDecoupleTestPeriod": 300,
    "caseLightPin": -1,
    "caseLightDefaultOn": "1",
    "bedSkipIfWithin": 3,
    "gen1T0": 25,
    "gen1R0": 100000,
    "gen1Beta": 4036,
    "gen1MinTemp": -20,
    "gen1MaxTemp": 300,
    "gen1R1": 0,
    "gen1R2": 4700,
    "gen2T0": 25,
    "gen2R0": 100000,
    "gen2Beta": 4036,
    "gen2MinTemp": -20,
    "gen2MaxTemp": 300,
    "gen2R1": 0,
    "gen2R2": 4700,
    "gen3T0": 25,
    "gen3R0": 100000,
    "gen3Beta": 4036,
    "gen3MinTemp": -20,
    "gen3MaxTemp": 300,
    "gen3R1": 0,
    "gen3R2": 4700,
    "userTable0": {
        "r1": 0,
        "r2": 4700,
        "temps": [
    "userTable1": {
        "r1": 0,
        "r2": 4700,
        "temps": [
    "userTable2": {
        "r1": 0,
        "r2": 4700,
        "temps": [
    "tempHysteresis": 0,
    "pidControlRange": 20,
    "skipM109Within": 2,
    "extruderFanCoolTemp": 50,
    "minTemp": 150,
    "maxTemp": 275,
    "minDefectTemp": -10,
    "maxDefectTemp": 290,
    "arcSupport": "1",
    "featureMemoryPositionWatchdog": "1",
    "forceChecksum": "0",
    "sdExtendedDir": "1",
    "featureFanControl": "1",
    "fanPin": "ORIG_FAN_PIN",
    "scalePidToMax": 0,
    "zProbePin": -1,
    "zProbeBedDistance": 10,
    "zProbePullup": "0",
    "zProbeOnHigh": "0",
    "zProbeXOffset": 0,
    "zProbeYOffset": 0,
    "zProbeWaitBeforeTest": "0",
    "zProbeSpeed": 2,
    "zProbeXYSpeed": 150,
    "zProbeHeight": 40,
    "zProbeStartScript": "",
    "zProbeFinishedScript": "",
    "featureAutolevel": "1",
    "zProbeX1": 20,
    "zProbeY1": 20,
    "zProbeX2": 160,
    "zProbeY2": 20,
    "zProbeX3": 100,
    "zProbeY3": 160,
    "zProbeSwitchingDistance": 1,
    "zProbeRepetitions": 1,
    "sdSupport": "0",
    "sdCardDetectPin": -1,
    "sdCardDetectInverted": "0",
    "uiStartScreenDelay": 1000,
    "xEndstopBackMove": 5,
    "yEndstopBackMove": 5,
    "zEndstopBackMove": 2,
    "xEndstopRetestFactor": 3,
    "yEndstopRetestFactor": 3,
    "zEndstopRetestFactor": 3,
    "xMinPin": "ORIG_X_MIN_PIN",
    "yMinPin": "ORIG_Y_MIN_PIN",
    "zMinPin": "ORIG_Z_MIN_PIN",
    "xMaxPin": "ORIG_X_MAX_PIN",
    "yMaxPin": "ORIG_Y_MAX_PIN",
    "zMaxPin": "ORIG_Z_MAX_PIN",
    "deltaHomeOnPower": "0",
    "fanBoardPin": -1,
    "heaterPWMSpeed": 0,
    "featureBabystepping": "1",
    "babystepMultiplicator": 1,
    "pdmForHeater": "0",
    "pdmForCooler": "0",
    "psOn": "ORIG_PS_ON_PIN",
    "mixingExtruder": "0",
    "decouplingTestMaxHoldVariance": 20,
    "decouplingTestMinTempRise": 1,
    "featureAxisComp": "0",
    "axisCompTanXY": 0,
    "axisCompTanXZ": 0,
    "axisCompTanYZ": 0,
    "retractOnPause": 2,
    "pauseStartCommands": "",
    "pauseEndCommands": "",
    "distortionCorrection": "0",
    "distortionCorrectionPoints": 5,
    "distortionCorrectionR": 100,
    "distortionPermanent": "1",
    "distortionUpdateFrequency": 15,
    "distortionStartDegrade": 0.5,
    "distortionEndDegrade": 1,
    "distortionExtrapolateCorners": "0",
    "sdRunOnStop": "",
    "sdStopHeaterMotorsOnStop": "1",
    "featureRetraction": "1",
    "autoretractEnabled": "0",
    "retractionLength": 3,
    "retractionLongLength": 13,
    "retractionSpeed": 40,
    "retractionZLift": 0,
    "retractionUndoExtraLength": 0,
    "retractionUndoExtraLongLength": 0,
    "retractionUndoSpeed": 20,
    "filamentChangeXPos": 0,
    "filamentChangeYPos": 0,
    "filamentChangeZAdd": 2,
    "filamentChangeRehome": 1,
    "filamentChangeShortRetract": 5,
    "filamentChangeLongRetract": 50,
    "fanKickstart": 200,
    "servo0StartPos": -1,
    "servo1StartPos": -1,
    "servo2StartPos": -1,
    "servo3StartPos": -1,
    "uiDynamicEncoderSpeed": "1",
    "uiServoControl": 0,
    "hasMAX6675": false,
    "hasMAX31855": false,
    "hasGeneric1": false,
    "hasGeneric2": false,
    "hasGeneric3": false,
    "hasUser0": false,
    "hasUser1": false,
    "hasUser2": false,
    "numExtruder": 1,
    "version": 92.2
========== End configuration string ==========
Earthbound
That Configuration.h contains:
So it is still associating EXT0 with thermistor at T0. If you want a thermistor connected to T3 to work for EXT0, change the line to read:
Eric
Post by Eric »
Earthbound wrote:That Configuration.h contains:
Except that he wanted it for the bed, not the hot end. So look at this line instead:
Which should NOT be pointing at the same pin as the EXT0 sensor! This also explains why changing pins.h was not getting you results. Change it to the right definition and the pins.h setting should work. Or just set it to 7 like Earth said, but then you must remember that you've bypassed pins.h for that setting!
Earthbound
Eric wrote: Except that he wanted it for the bed, not the hot end. So look at this line instead:
Hmmmm, I seem to have misread the original post and forged blindly ahead.
Might have changed in Repetier 0.92, but as of 0.91 I don't think pins.h defined TEMP_3_PIN for the RAMBo. At least I didn't see it when I read it a couple of weeks ago. Of course, my track record on reading things has been sullied recently.
Eric
Post by Eric »
In 0.91 it would have been TEMP_BED_PIN, but that seems to have gone away in 0.92 (https://github.com/luc-github/Repetier- ... ier/pins.h), probably to make it conform better to the newish configuration tool (which I've never used myself). What is most important is that each sensor be assigned it's own definition, not that the definition have a particular number on it. It was probably supposed to be TEMP_1_PIN (because the next line uses HEATER_1_PIN). You don't need to define a TEMP_3_PIN (although you could), you just need to change the value of TEMP_1_PIN in pins.h to what you need. The idea is that you keep the hardware assignments in pins.h, and you don't change that reference line in configuration.h. You don't have to conform to that ideal of course, but then you're subject to new pitfalls, such as later forgetting the pins.h changes aren't going to work.
Earthbound
I feel pins.h should be left alone. It's function is to provide the pinout data for Repetier to function on a plethora of different boards. TEMP_n_PIN is the RAMBo i/o pin of connector Tn. It is simply a description of the circuit board layout.
Configuration.h is the playground for implementing Repetier on a particular machine. Here is the place to describe how the board is connected to the external components.
Eric
Post by Eric »
Earthbound wrote:I feel pins.h should be left alone. It's function is to provide the pinout data for Repetier to function on a plethora of different boards. TEMP_n_PIN is the RAMBo i/o pin of connector Tn. It is simply a description of the circuit board layout.
I agree that the function of pins.h is to contain hardware data, which is why I discouraged hardcoding pin 7 in configuration.h instead of using a pins.h reference. As for the rest of your plan, that would be a great if pins.h were ordered and complete as delivered. But it's neither of those. For the 0.92 pins.h I linked above you start with Rambo defines:
#define HEATER_0_PIN 9
#define TEMP_0_PIN 0
#define HEATER_1_PIN 3
#define TEMP_1_PIN 2
#define HEATER_2_PIN 7
#define TEMP_2_PIN 1
Which is, in order from the Rambo Schematic: Heat-0, Therm0, Bed-Heat, Therm2, Heat-1, Therm1. There's also another define for Fan-0. Therm2, Fan-1, and Fan-2 aren't to be found unless you add them. There's no CLEAN way to avoid editing pins.h if you want to use those I/O pins. You're free to add TEMP_3_PIN of course, but there's no designated HEATER_3_PIN to associate with it unless you re-purpose the Fan-0 output (Fan-1 and 2 use lightweight mosfets).
There's a historical reason for the ordering too, from the development of RAMPS and the like. First there was the hotend, and people were amazed. Then there was the heated bed, and life was better. And then there was everything else. And on the 7th day you finally had the machine calibrated....maybe.
