Thanks in advance
Sorry can you explain this in more detail if you can? Im not very experienced with 3D Printing so theres still a lot i need to learnJ.R. Spencer jr wrote:First thing out check the thermister for an open. Then test the resistance ( ohms) across the leads disconnected from the Rambo board, then move and flex the leads to see if that causes an open ( infinite resistance) across the heated bed. If you find something an intermittent open, then where ever your flexing is close to the problem. These thin wires can be very fragile. If nothing showed up try flexing the onyx board itself, only slightly. If an open shows then its the onyx board? I had a lot of problems with the connections to the Rambo. Always check your connections first. Good luck J.R.
He is saying that you purchase or borrow a multimeter that can read ohms and using the ohms function of the multimeter to perform the tests that he mentions. If you have no basic knowledge of what a multimeter is and how to use one perhaps you can\Nazulle wrote:Sorry can you explain this in more detail if you can? Im not very experienced with 3D Printing so theres still a lot i need to learnJ.R. Spencer jr wrote:First thing out check the thermister for an open. Then test the resistance ( ohms) across the leads disconnected from the Rambo board, then move and flex the leads to see if that causes an open ( infinite resistance) across the heated bed. If you find something an intermittent open, then where ever your flexing is close to the problem. These thin wires can be very fragile. If nothing showed up try flexing the onyx board itself, only slightly. If an open shows then its the onyx board? I had a lot of problems with the connections to the Rambo. Always check your connections first. Good luck J.R.
