Change slicers
fuhao1995323
Change slicers
Post by fuhao1995323 »
Hello all,
Can anyone tell us how to change the slicer?
And what else calibration of printer we need to redo?
Thank you very much!
Dale Eason
Re: Change slicers
Post by Dale Eason »
If you are using MatterControl then click on the "configuration" heading. Then look down the screen as find the "slicer engine" selection box. I don't think there is a need to change calibration setting. However each slicer has a slightly different set of parameters and options. The most important ones for all slicers are filament properties, bed size, nozzle size, temperature, layer height, infill, support, and speed settings. Each have some version of those and if you have known good values for one slicer try using them to start with.
Dale
