How much filament?
SFX Group
How much filament?
Post by SFX Group »
Hi
I have never 3D printed before, i have a model and it says "218653.00mm" of filament needed, so how much do you get on a spool (which is either 1 or 2 pounds)?
Many Thanks
Ashley
© Copyright 2011 - http://www.ashleygriffin.ca
Re: How much filament?
Post by Mac The Knife »
roughly 400,000 mm of ABS on a 1 Kg spool, 330,000 mm of PLA.
SFX Group
Post by SFX Group »
Mac The Knife wrote:roughly 400,000 mm of ABS on a 1 Kg spool, 330,000 mm of PLA.
Thanks
This is going to eat through filament then.... handy to know.
Will the printer stop and wait for a re-load or will i need to hope i have enough?
Rostock MAX v2, what does this printer do when it runs out of filament?
Many Thanks
Ashley
bot
Post by bot »
The printer just keeps going, it has no idea if you have filament or spaghetti running through it. By running the print from host software with the printer connected to a PC, the print can be paused, and filament reloaded manually. You could also manually split the g-code file into two separate parts where you estimate a reload will be needed.
*not actually a robot
SFX Group
Post by SFX Group »
bot wrote:The printer just keeps going, it has no idea if you have filament or spaghetti running through it. By running the print from host software with the printer connected to a PC, the print can be paused, and filament reloaded manually. You could also manually split the g-code file into two separate parts where you estimate a reload will be needed.
That sounds like a plan (pausing the printer), is there any filament splicing tool?
I assume if you pause and reload, is there a chance your get a "missed" gap or is the filament under pressure so any gaps will be pushed out by filament pressure (i'll have to test this).
Many Thanks
Ashley
bot
Post by bot »
I have never done this myself. You would definitely want to manually purge the extruder to get as consistent pressure as you can when you restart. I would actually print a sacrificial "tower" that I could pause the print at. So it pauses and resumes while it is printing the small part that I don't care about.
I have paused my printer while it is printing infill, pulled the filament, inserted the new filament, made sure it was primed by manually turning the motor, and then resume printing.
