I've learned a few things since that post, yep. I also changed the design a bit so that it requires less support. That's obviously the question to ask first.
When I was printing those parts, I was also using the "grid" shaped support material instead of "lines" in Cura, and I had to have the support infill % turned down because it would stick to the part too badly to remove if it was any higher. I've started using the linear support option since then and can make the support infill much more dense and still remove it. This is a recent example of a part I did:
[img]
http://i.imgur.com/5SrLoMW.png[/img]
I've also learned some neat tricks for using MeshMixer to do "tree" supports on complex parts.
[youtube]
http://www.youtube.com/watch?v=aFTyTV3wwsE[/youtube]
Bridges are easier to do than overhangs. It's easier to string filament up between two objects than it is to float it out in mid air. Go for an isthmus instead of peninsulas
High temps and quick speeds also seem to help, but reading other people's posts, it seems like there's a little bit of voodoo here and your mileage may vary.
Show us your part. Sometimes seeing it with a different set of eyes is the ticket.
