Not sure how else to describe this. I am getting pitting on the surface of the print. The weird thing is that I printed this with 0 retraction! (because I thought the issue was retraction). I'm using Cura to slice. any ideas?
[img]http://i.imgur.com/aOIzocPl.jpg[/img]
							Pitting on surface finish
- jeffhuber
Rostock max v2 with e3d v6
				Earthbound
Re: Pitting on surface finish
Air bubbles in the filament?
If it was trapped moisture, I wouldn't expect the rest of it to look so nice.
						- jeffhuber
it feels like 1 per layer - and often times they will "stack up" and be at the same place
so i doubt it's that :/
Does it happen with other slicers too?
						- jeffhuber
havent tested that yet! good question though - i will try that
						- jeffhuber
Printing with Slic3r seemed to help the problem (although it introduced others). I vastly prefer Cura for surface finish. anyone have experience with Cura and what might cause this or what to tinker with?
Do you here pops when printing?  This looks a little like the problems I had when I got a bad roll of filament with moisture problems.  I dried it out in a ziplock storage bag with one of those silica dehumidifiers and it started printing OK again.
