Steppers don't turn
scgtrp
Steppers don't turn
Post by scgtrp »
I've just built a Rostock Max V2. The heaters and the extruder motor appear to work, but the other three motors don't even attempt to turn.
Things I've tried:
- Repeatedly turning it off and on again.
- Moving it via every method I could think of (the movement and homing buttons in Pronterface, the LCD menus, manually typing G0 lines into the console, telekinesis). None of these worked.
- Flipping one of the motor connectors.
- Swapping one of the axis motors with the extruder. The axis motor turns; the extruder motor doesn't. I'd think this was a bad stepper driver, but 3 of them on the same board?
- The endstops are all reported low by M119 and change to high when I press them manually.
I also had to replace the included 450W power supply with a 350W one borrowed from my old printer, because the included one wouldn't power on. I don't think that's it, though, since one of the motors does work (also, I don't know the power requirements of those motors but I'm pretty sure it's not >350W each).
I have the "different" motor connectors mentioned on page 194 of the assembly guide, in case that's relevant.
Suggest other things to try?
scgtrp
Re: Steppers don't turn
Post by scgtrp »
Never mind, fixed.
For anyone who shows up here searching: I compiled the firmware with Arduino 1.5 instead of 1.0. Not sure why that fixed it, but it did. (Not mixing up the Y and Z axes made it work even better.)
scgtrp wrote:Never mind, fixed.
I am glad that you got it fixed. Telling us the solution helps everyone, thanks!
