RADIAL FAN HOUSING TO FIT TRICKLASER & MAX 2
Post your prints with the GCode used to help other users achieve a similar result, or get help.
draw-tech
Post by draw-tech »
Hi all
Here is a file to fit the Tricklaser to the radial housing for the Rostock Max 2
I have added some material around the fan port, this can be removed after printing. Print with support setting on the fan port.
Draw-Tech
Snapshot 1 (6-7-2015 11-12 AM).jpg (8.73 KiB) Viewed 14484 times
I printed the fan Radial Housing2.pdf
(197.88 KiB) Downloaded 622 times
Fan_Housing_TrickLight_9_.025.stl
(2.42 MiB) Downloaded 543 times
Return to “GCode & Test Prints”
