Rostock Max stops during print "Cannot connect to printer"
beilmandesign
Post by beilmandesign »
Any ideas or similar experiences to share?
The problem I am seeing is that the printer stops mid-print. If I try the same file it stops at various stages and never in the same place. Mattercontrol says it has stopped working and if I restart it cannot connect to the printer. A restart is required to clear my com port 7.
This is happening on every build & every file I try. I have over 200 hours previously with no issues.
Reboots, & re-installation of the Rambo drivers have had no effect.
Thanks in advance.
teoman
Re: Rostock Max stops during print "Cannot connect to printe
Post by teoman »
Did you try the sd card?
That way you can know if it is the computer or the rambo.
beilmandesign
Yes, Sorry I should have provided that information in my original message. Using the SD card exhibits the same mid-print freeze-up problem.
beilmandesign
I removed the acrylic panel on the side of the enclosure and aimed a small fan directly at the rambo board - problem solved.
