Hi, I've had the Max v2 for about five months now and had no real problems other than replacing the thimester? (suckers just so small and thin) but now the hot end is giving me fits.
About 2 weeks ago, it stopped reaching working temp. Temps will get anywhere from 23 to 18 degrees to working temps and then stop, hover around that and then start dropping.
Now here is the part that has me really going nuts, when I run the PID to test the hot end, it works fine like nothing wrong!
So I've run the PID test, set the temp manually at the printer, went to print connected and disconnect from computer (win7), checked the wiring at the hot end and board (which is fine), so
right now the PID test is the only thing that will get up to operating temp. Any ideas on how to solve this would be great (btw it's a stock printer) . . . . . thanks.
Hot End Temps Falls Short
Re: Hot End Temps Falls Short
Have you tried printing without the bed heated? Yes, the print won't stick, but if the hotend gets up to temperature that way, I would look first at where the power connects to the printer, make sure the connections are tight, they have loosened up for some people. Second would be to measure the power supply voltage when both the hotend and bed are heating.
- Noob
Thanks MTK, I checked the power connectors on the board and some of them were loose. Next I tried to print w/the bed heating up and when the temp stop rising at about 180 something I turned the bed temp down to 0. The temp did get up to within 3 deg (set at 200 got to 177/8) so still no printing. I don't have a volt meter and not sure which one would best serve me since I've never had a use for one. I'm guessing that the readings should be between a certain number and if so what would that be if both bed and hot end are heating up?
Check the connection near your hotend, where you crimped the resistor leads to the 18 gauge wire. I bet it's charred and falling apart. Time to replace and redo that, I bet.
*not actually a robot
take a mulimater and check the resistance on the hotend resistors I think you shoud have a reading of about 3.5 to 4 ohms.
if not then one of the resistors is nor working
- Noob
Thanks all, after closer inspection of the hot end, both leads and trimester(I know it's spelled wrong) were wobbling in their sockets. So instead of going through this
every two or three months, I'm thinking to go with the e3d v6 hot end. Not sure if I want to with the 24v or stick with the 12v and keep the same power supply.
I'll read through the form to see what others have to say about it.
Again, thanks
Again, thanks
- Noob
Hi all, I'm back.... so after pulling all the leads from the board checking for charred ends/loose connections and reseating them, I pulled
the heated bed and checked that. With out routing the wires just connected them and tested again. Hot end heats up fine reached temps
no prob. As soon as the bed temp is turned on the peek fan slows down and hot end temps start dropping. I checked the fuse which is
fine. Could it be the power supply or some other thing on the board that's not regulating power correctly? BTW the bed reaches temp
regardless.
regardless.
Dude. Paragraphs!
