my heated bed is showing a 12 degree difference between my thermocouple on my meter and the thermistor in the bed. this is with the glass on. is there a line in the config,h for the bed that will allow a change like you can do with the hotend.
Tom C
heated bed calibration
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Re: heated bed calibration
The top of the glass could be 12 degs colder.
well that sucks. I know there will be some difference, but that puts the edges of the bed to around 60, anything below 70 and I get curling on the edges with abs. I guess after I crank it up to 24 volts (still have not gotten my second SSR from amazon) I will just have to run the temp up until it actually is hot enough on the perimeter.
Tom C
Tom C
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
I was wondering the same thing. Why is there a process for calibrating the hotend, but no calibration process for the heated bed?
The heated bed calibration use to be in the manual (last revision I think), not sure why it was pulled.
I believe this is the correct code for 80c. M303 P1 S80
Edit, didnt mean 180
You can change the thermistor type to be custom, calculated from a Beta value, then tweak that beta value to match the actual temperature in the range you usually measure.
I do this with my hot-end, though mostly because the thermistors supplied with the E3D hotends I have were miles off.
I usually don't bother with the bed, I just know that with it set to 80C whatever the actual temperature is sufficient to print with ABS, 60C for PLA etc.
Thanks. I'll try that. My fan shroud came off the bed about 75% of the way through my first ever print, so I'm concerned the temperature was lower than it needed to be for good adhesion.KAS wrote:The heated bed calibration use to be in the manual (last revision I think), not sure why it was pulled.
Edit, didnt mean 180 :)
